GSR tranny fit LS block?
well i checked the website where i got the clutch and the product #'s for both GSR and LS OEM replacement clutches are the same...
Assuming you don't break anything during the removal, and that the new transmission has no issues, it's as simple as removing some bolts, pulling off the transmission, slapping the new one on, and putting those bolts back in
Yup all B-series trans will bolt up to all B-Series blocks, the only thing you have to look out for when getting into the DA is that the 90-91 has a different spline than the rest do. And there are plenty of conversion kits out there if you decide in time to go with a hydro trans. Had a 95 GS-R (hydro) trans in my 92 GS (cable) with the hasport kit, worked great.
rewerbcrx
10
Sep 1, 2007 06:38 AM
