96 accord lx with f22b swap questions
i have a 96 accord lx that originally had a f22b2. i just swapped in an obd1 f22b and transmission. im using the original wiring harness, oil pump, crank sensor, throttle body, and exhaust manifold. im now having problems getting it running.
- can i use the original ecu on the new f22b engine?
- can i re-use the original obd2 external coil distributor on the new f22b engine?
- if i cant re-use the distributor how do i wire up the internal coil distributor?
- if i can re-use the distributor how do i make it work b/c they have different bolt patterns
- will the transmission work ok using the original electronics?
Angeljavier3577
Apr 30, 2018 01:41 PM
DVSRMZ450
Dec 9, 2012 07:43 PM
C_Rock77
Apr 21, 2010 07:44 PM
JSMC
Sep 5, 2007 05:00 PM
dominate9
Nov 1, 2002 06:43 AM
