RHD Integra-getting no spark
Old Nov 16, 2008 | 03:48 PM
dapek's Avatar
Default RHD Integra-getting no spark
Hey guys, my buddies rhd teggy was leaking water when it rains a bit near the drivers side firewall and the water was going onto the floor by the ecu. We fixed the leak but now the car keeps dying out on him and sometimes won't start. It's getting fuel and all, and there is no check engine light either to jump the code and the car isn't getting any spark?? Does anyone know what the problem could be? Maybe needs a new ecu? Also tried a few different distributors, all were from teh exact same engine and still didn't work. Thanks
Modified by dapek at 5:17 PM 11/16/2008
Old Nov 16, 2008 | 03:54 PM
dc2kidd's Avatar
Default Re: RHD Integra-getting no spark (dapek)
could be an electrical problem.. you could check the dizzy or see if you ignition coil has gone bad... i had this problem a while back.. good luck
Old Nov 16, 2008 | 04:04 PM
dapek's Avatar
Default Re: RHD Integra-getting no spark (dc2kidd)
ok thanks man how will i know if the dizzy is messed up? Anyone else, other ideas to help?
Old Nov 16, 2008 | 04:17 PM
dapek's Avatar
well the whole distributor was replaced to see if that was the problem and still nothing
Old Nov 16, 2008 | 05:00 PM
dapek's Avatar
bump, replaced MAP sensor and tried a gsr ecu. Still no spark
Old Nov 16, 2008 | 06:23 PM
dapek's Avatar
bump no one?
Old Nov 23, 2008 | 04:40 PM
gsrstick's Avatar
check relay box , may have shorted out. idk just trying to help
Old Nov 23, 2008 | 07:44 PM
jdmbaybaby05's Avatar
did you use the same ignition coil with each dizzy? or different one?
Old Nov 24, 2008 | 08:45 AM
Dunc's Avatar
BCICAN
Does it have spark plugs in it?
Old Nov 24, 2008 | 10:07 AM
twentyhurtz's Avatar
here is your problem, you have a rhd teg with a left hand drive engine, you need this motor here, ha ha jk
grandtheftlunchbox
Oct 12, 2008 05:51 PM
JorgeYaHeard
Jul 25, 2007 08:35 AM
sicegcivic
May 30, 2006 02:12 PM
Mandeep
Jul 17, 2005 11:33 PM
KimChiKid
Aug 10, 2003 05:37 AM
