cel 10 IAT and bogging
Old Nov 15, 2008 | 04:52 PM
GYChris's Avatar
Default cel 10 IAT and bogging
I just got 94 lsvtec hatch with b18b1 and b16 head (not sure the year, but it says PR3.) and chipped p28
The car bogs like hell when the gas is applied and barely moves at all. Now if i press the pedal maybe not even 1/8th of the way it does it way less. This problem occurs the whole time when cold and less when at operating temperature. The CEL is reading 10 which is IAT (Idle Air Temperature) I am not familiar with the IAT sensor and its location, but from what i've read it seems if there is a block off on the IM than it should be in/around the air box or intake piping? The intake manifold i have has the blocked off IAT spot on it. Would this CEL 10 be the reason for the bogging or is this a combination of problems? Where do i start to fix this problem? Thanks
****also i'd like to add that the bogging isnt as bad above about 3000-3500 rpms
Modified by GYChris at 6:03 PM 11/15/2008
Old Nov 15, 2008 | 04:53 PM
z6hatchboy's Avatar
Its on the i/m manifold, on the right side of it either on the runner i think. Its white
Old Nov 15, 2008 | 04:54 PM
GYChris's Avatar
Default Re: cel 10 IAT and bogging (GYChris)
I see the spot for it, but its blocked off from the factory... just blank
Old Nov 15, 2008 | 05:19 PM
96-EJ6 B18C's Avatar
Sounds like it's an OBDII manifold, they have the IAT in the intake tube. The simpleist fix is to just run the OBDII IAT in the intake tube. All you need is the sensor and connector, then just wire the connector on to your harness and drill a hole in the intake tube for the sensor, install the sensor in the tube using a rubber gromet.
Old Nov 15, 2008 | 05:27 PM
GYChris's Avatar
Default Re: cel 10 IAT and bogging (96-EJ6 B18C)
thanks for the input. So I guess i am not even running an IAT sensor... Do you think this could be causing my bogging problem? Also, do you know which wires on the harness are for the IAT? Thanks once again!
Old Nov 15, 2008 | 05:36 PM
Yes, running with out the IAT will cause that. The wires you'll be looking for in the harness will be connected to a 2-pin connector (if memory serves me correctly that connector will be white rather than the usual grey, but the wire colors will seal the deal) located toward the back of the intake manifold on the driver's side (they will probably be loomed with another 2-pin connector do not get these mixed up) The IAT wire will be red/yel and grn/wht. The other connector that the IAT is loomed with is the EVAP solenoid connector it will be yel/blk and red. Just extend the IAT wires to the intake tube and install the OBDII IAT connector (it's squareish rather than round).
Old Nov 15, 2008 | 06:18 PM
GYChris's Avatar
Thanks once again man, Its funny because there are 2 separate sets of 2 wires each laying loose behind the intake. Really appreciate it!
Old Nov 15, 2008 | 06:31 PM
Anytime
Old Nov 15, 2008 | 06:50 PM
GYChris's Avatar
i'll keep you posted if it works or not. Just gotta find me a sensor now!
Old Nov 15, 2008 | 06:56 PM
Thizzed Out's Avatar
Will cel 10 also cause a car to idle at 2000ish when cold? i have the same cell but i also just replace my Throttle Body so it could maybe have been that? Lol sorry im not trying to thread jack
Old Nov 15, 2008 | 07:00 PM
GYChris's Avatar
Default Re: cel 10 IAT and bogging (Thizzed Out)
No problem man, don't think i could answer your question... but mine is idling around 1100 whether its cold or not.
Old Nov 15, 2008 | 07:05 PM
when warm mine idles at 6-800 but yeah let us know if yours get's fixed
Old Nov 16, 2008 | 10:18 AM
Sounds to me like your FITV (fast idle thermo valve) is loose. This is very common and easy to fix. This can be done without removing the valve but if you've never done it before it may be easier with it off the throttle body (if you want to remove it just remove the coolant line and the three 10mm bolts that hold it on). On the bottom of the throttle body there is a small valve with a small coolant line going to it, on the back (firewall side) there is a plate that's held on by two 8mm screws. Remove those screws along with the cover plate, inside you will find a white plastic piece with slots for a flat blade screw driver toward the outer edge, simply spin the entire white piece clockwise until it is snug in the valve and reinstall everything in the reverse order.
Old Nov 16, 2008 | 05:20 PM
I know extacty what you are talking about. When replacing the throttle body I went ahead an cleaned the fitv and it was abit loose but I didn't think anything of it. If I screw it in more would it cause me to idle even lower when warm? When warm it's perfect I just need it to idle good when cold.
Old Nov 16, 2008 | 07:07 PM
FITV shouldn't affect warm idle speed.
Old Nov 16, 2008 | 07:11 PM
thanks for the info I'll try this out tomorrow morning
Old Nov 16, 2008 | 07:14 PM
's first!
Old Nov 23, 2008 | 05:32 AM
GYChris's Avatar
Well i plugged in a IAT sensor and it runs alot better. Im guessing it still has multiple problems because it still bogs/ breaks up periodically while accelerating. So i was looking around the engine bay and noticed there are no o2 sensors. It has a header so the only spot for an o2 is straight below the intake manifold and there is a bolt stuck in there. Will running no 02 sensor cause funny running?
Old Nov 23, 2008 | 02:14 PM
GYChris's Avatar
bump, any help? will running without an o2 sensor cause running problems?
Old Nov 23, 2008 | 03:34 PM
b16_sol_707's Avatar
yes the missing o2 sensor will cause running issues.
himhimself
Aug 16, 2009 06:23 AM
EKSedAndy
Sep 22, 2008 08:12 PM
Sleepin Crx
Apr 3, 2004 03:47 AM
red_sir
May 15, 2003 11:48 PM
9d9GSR
Aug 15, 2002 05:21 PM
