Do I have to gap my NGK's?
Old Nov 15, 2008 | 09:54 AM
BoltonGSR's Avatar
Default Do I have to gap my NGK's?
I just got some NGK iridium (ZFR5FIX-11) for my B20.
Do I gap them?
Old Nov 15, 2008 | 10:27 AM
Tegraracer90's Avatar
Default Re: Do I have to gap my NGK's? (BoltonGSR)
read a shop manual, see what the gap is soposed to be...go to discount auto store get a 2-in-1 gapping tool/gauge....check the gap right out of the box...if it doesnt match what the manual says its soposed to be....gap it
Old Nov 15, 2008 | 11:38 AM
kyorishin's Avatar
if you told them the right model of the engine the spark plugs should already come pre gapd
Old Nov 15, 2008 | 12:18 PM
CompanyFlow's Avatar
Default Re: (kyorishin)
I have never had a full set at the same gap. People touch them all the time, not to mention how many different applications there are for each plug.
Old Nov 15, 2008 | 01:59 PM
JRSC01GS-R's Avatar
Default Re: (CompanyFlow)
they are supposed to come gapped, but never install them without at least checking the gap's to ensure they are all the same, whats it take 30 sec to check the gap on 4 plugs?
Old Nov 15, 2008 | 02:13 PM
kronikSLOW's Avatar
Default Re: (JRSC01GS-R)
is your engine modded? if not why did you buy iridum plugs? the only difference between a 10 dollar plug and 1.50 plug is how long they last but you whould have to replace the irridums 2 times before it whould equal changing the v powers to 5 times to spend the same amount of time. always check your gap. and it only takes 5 minutes to change plugs so save 50.00 dollars and spend an extra 25 minutes on your engine and buy v power ftw.
Old Nov 15, 2008 | 07:43 PM
Mosher27's Avatar
First off Kronik is dead wrong, Iridium plugs spark hotter, are more efficient, and the iridium core is more conductive, there is less resistance than the vpower. But yes, always check the gap. I work at AutoZone and have seen the way plugs are shipped, they get bumped around in shipping and handling, so always check. The plugs that you do no need to gap are the plugs that have more than one ground strap, like the Bosch PLus 2,4, ect.
Old Nov 15, 2008 | 07:46 PM
BoltonGSR's Avatar
Default Re: (Mosher27)
So if the gap is incorrect. How exactly would I go about fixing it? Do I just pry on the electrode?
Old Nov 15, 2008 | 07:52 PM
majinsoftware's Avatar
yup just bend it to right gap.
Old Nov 15, 2008 | 09:38 PM
ruffrhyder's Avatar
I worked at AZ also, and the mis-handling of the product wouldn't be an issue since the electrode end of the plugs are sleeved with a plastic cover so there shouldn't be difference in the gaps.
Please explain how can Iridium be more conductive and have less resistance than copper?
Explain something else to me,, how will an Ir plug have a hotter spark than say a copper plug if the ignition system is putting out the same amount of voltage?
Modified by ruffrhyder at 10:43 PM 11/15/2008
Modified by ruffrhyder at 10:46 PM 11/15/2008
Old Nov 16, 2008 | 07:54 AM
BoltonGSR's Avatar
ZFR5FIX-11 are the plugs i got. The gap is supposed to be 1.1 mm, is that what the 11 stands for here?
ZFR5FIX-11
I dont why it doesnt just outright say what the gap is on the damn box.
Old Nov 16, 2008 | 08:36 AM
ruffrhyder's Avatar
ZFR5FIX-11
It somewhat does
Yes the "11" stands for 1.1mm which is equal to .0433 inches. What is your CR?
Old Nov 16, 2008 | 09:28 AM
BoltonGSR's Avatar
Default Re: Do I have to gap my NGK's? (ruffrhyder)
Originally Posted by ruffrhyder
It somewhat does
I just checked them and they were at like .0388 inches.
Does that little difference really matter?
My JDM B20 is at its stock CR of 9:6:1
Old Nov 16, 2008 | 09:44 AM
ruffrhyder's Avatar
Are you using feeler gauges or ramp style gapper? I would open them up a bit, since your CR is low I would try even .052" like stock GSR. You want to utilize the widest gap possible without blowout, in theory it should improve the flame kernel. But this is hard to determine w/o dyno time.
blazinxhott
Acura TL, RL & ZDX
Sep 24, 2009 09:09 AM
dogbiscuit
25
Nov 2, 2005 11:47 AM
pa2play
Jul 25, 2004 01:15 PM
Thrillhouse
Apr 14, 2003 10:21 AM
HondaJon
Jul 28, 2002 05:10 PM
