SRS Airbag issues . . .
does anybody know how to turn on the SRS light on the gauge cluster without having the drivers side airbag for a 94 integra because i have a JDM racing stewering wheel with no airbag on my it & because i failed inspection because the light didnt turn on
. . . . help please
. . . . help please
. . . . help please
. . . . help please
You could do something illegal and dodgy by hooking it up to one of the other lights power source in the dash.
Thats what a few people do when they import cars that had air bags that had gone off and cant afford to replace them and get the car inspected and re vinned.
Pull the cluster out, Solder some wires onto the CEL(check engine light) bulb then run them to the SRS bulb,
Its easyer using a non stock LED which doesnt use the SRS blubs connection points so then you dont need to worry about cutting the traces. But the only problem then is mounting the bulb so you will need to use some silicon or glue to hold it in place.
If your not good with electronics ask a friend that is and they should be able to do it in a few secs. Or take it to a electricians and ask them to wire the SRS to the CEL bulb.
ih8speedbumps
Jan 2, 2014 04:42 PM
RineRacing
20
Jan 24, 2003 06:55 AM
