blown head gasket
Old Nov 13, 2008 | 11:50 AM
h3rsh3y2001's Avatar
Default blown head gasket
is it possible to replace my head gasket myself?
in your opinion what is the best replacement gasket?
if I smell a sweet smell in the valve cover(oil cap area) that means I am getting coolant into my cylinders, but I dont see white smoke and there is no loss in coolant, what else could it be?
any help would be great cause I've been chasing a gremlin for a while and I think i found were he was hiding, I just can pin point it.
Old Nov 13, 2008 | 12:00 PM
teefunk01's Avatar
Default Re: blown head gasket (h3rsh3y2001)
Do a compression test on the motor. A headgasket can be hard if you have never performed one before. Make sure you use an oem gasket from honda.
Old Nov 13, 2008 | 12:02 PM
SKDRCR's Avatar
Default Re: blown head gasket (teefunk01)
Yep and Yep
If you're not familiar with it definitely purchase a helms manual.
Old Nov 13, 2008 | 12:15 PM
Default Re: blown head gasket (SKDRCR)
i thought about the compresion check, would that tell me if a seal was bad?
and if I get one done and the compresion is fine then what?
Old Nov 13, 2008 | 12:20 PM
teefunk01's Avatar
The only time that I have seen a headgasket that wasnt sealing properly but still came out with good compression was on boosted motors. And thats only because of poor headstuds that would cause the head to lift under boost. Other than that if you think its your headgasket most likely youll have poor compression
Old Nov 13, 2008 | 12:21 PM
can any auto repair shop do one or do i have to take it to a performance shop?
Old Nov 13, 2008 | 12:36 PM
f22builder's Avatar
You could buy a compression tester. DO NOT GET ONE FROM WALMART. Unplug your ignition coil so you do not get any spark in the cyclinders. Then take out all your spark plugs or one at a time. Install compression tester with a little oil on the threads. Crank car I believe 7 times. Check compression and compare to what it should be compared to owners manual. If the cyclinder you test is really low compared to the other cyclinders you can add a small spoon full of motor oil in the spark plug hole. DO the compression check again and compare. If it goes up a lot you may need new rings if it still is low you may have a bent valve.
Let us know your cyclinder numbers
Old Nov 13, 2008 | 12:41 PM
teefunk01's Avatar
Default Re: blown head gasket (f22builder)
keep in mind all the cylinders should be no more then 10% off from the other cylinder
keep us posted with what the compression reads in each cylinder we are here to help out
Old Nov 13, 2008 | 02:42 PM
AndyD's Avatar
Is your car running fine right now?
Have you changed your oil yet?
Old Nov 13, 2008 | 03:19 PM
Default Re: blown head gasket (AndyD)
you can hear the mis fire between 1500-2200rpm i change the oil a few hundred miles before its due only cause my oil light will come on.
Old Nov 13, 2008 | 03:28 PM
AndyD's Avatar
If that's all you're experiencing, I doubt the head gasket is bad.
Oil didn't look unusual? Pay close attention to your oil level everytime you get gas. See if it's getting lower.
Where in MD do you live? If you're close, maybe I can check out your car.
Old Nov 13, 2008 | 06:00 PM
next friday I'll be in gaithersburg at my uncles shop and for the rest of that weekend I'll be on the eastern shore. Im stationed in norfolk so I go home just about every other weekend.
Old Nov 15, 2008 | 12:37 AM
Im starting to think its my valve seal cause i just noticed oil on the intake manifold, which is why i prolly haven't been able to smell burning oil.
shm91
Sep 1, 2013 03:56 AM
ordale
Feb 17, 2008 09:26 AM
sleepyIntegra
May 24, 2004 11:14 AM
redcivic
Apr 22, 2003 03:54 PM
Eg6_JDM
Oct 26, 2002 07:59 AM
