How did you wire your full throttle shift? (hondata)
Old Nov 12, 2008 | 05:31 PM
justinCO's Avatar
Default How did you wire your full throttle shift? (hondata)
I hear hondata suggesting to use the "cruise control" clutch switch on the clutch pedal, but my car doesn't have that (unless I'm looking in the wrong spot). Should I use the clutch switch that gets depressed when the pedal is pushed to the floor (one for starting car)???.
What other options are there? Can I get a new switch (off a junkyard car?) and put it where the clutch pedal stop (the adjustment bolt when clutch is out) is on my car currently?
Justin
edit: this probably should have been created in engine management & tuning, sorry.
Old Nov 12, 2008 | 06:06 PM
mr.sky's Avatar
I used a cruise control switch off a DA integra, put it where the clutch pedal stop bolt thing is. Ground the ground, attatched the signal to the A/C input from the ECU
Old Nov 12, 2008 | 06:16 PM
justinCO's Avatar
Default Re: (mr.sky)
Thanks, that is exactly what I was looking for. I'll try to find a cruise control switch. Going to wire mine to input for power steering and use a/c button/input for high/low boost.
Justin
Old Nov 13, 2008 | 03:37 PM
justinCO's Avatar
Default Re: (justinCO)
Well, I got a cruise control switch but no plug for it. Anyone know which prong on the switch plug is the ground??
Justin
Old Nov 13, 2008 | 03:53 PM
HiProfile's Avatar
I think the switches are polarity-neutral, per se, if you wire them up custom. One went to ground (or positive), one went to the ecu. IDK if the clutch switch is N.O. or N.C., but I do know most brake switches are both N.O. and N.C., and use the normal 4-pin relay plug. In my auto-to-manual swaped EF I forgot to take the clutch switch plug, so I used the old brake switch to disable my cruise. I like disengaging it smoothly...
FYI cars that didn't come with cruise (DX, CX, etc) didn't seem to have the same pedal assembly - no spot to mount the top clutch switch. Its not hard to rig it up if you can weld.
Old Nov 13, 2008 | 04:24 PM
justinCO's Avatar
Default Re: (HiProfile)
Hmm ok. Maybe I'll wire it up and test it, see if it works.
My car (DX) does have the spot on the pedal assembly for the cruise switch, it is just occupied by the clutch slack adjustment bolt right now.
Justin
Old Nov 13, 2008 | 05:27 PM
mr.sky's Avatar
correct it doesnt matter which way round the wires go its just a switched earth
Old Nov 13, 2008 | 05:35 PM
justinCO's Avatar
Right on, now I just need to find a plug that fits it. Thx guys!
Justin
Old Nov 14, 2008 | 08:18 AM
92integraVTECgsr's Avatar
what exactly does the full throttle shift do?
It came with my Hondata S200, but I never hooked it up.
Old Nov 14, 2008 | 10:19 AM
justinCO's Avatar
Default Re: (92integraVTECgsr)
Exactly what it says. Keep full throttle and shift Basically it will lower the rpms a tad when you push in the clutch to shift, like a temporary rev limiter.
Justin
Old Nov 14, 2008 | 12:12 PM
so do you still take your foot off the gas?
Old Nov 14, 2008 | 12:34 PM
justinCO's Avatar
No, gas pedal stays to the floor throughout the shift. Just hold gas down and shift through the gears, hondata takes care of lowering the rpms a tad when you push in the clutch.
Justin
Old Nov 14, 2008 | 09:01 PM
V-SPEC 1's Avatar
Let us know when you get it to work. Hurry so I can hook mine up too.
Old Nov 14, 2008 | 09:17 PM
96 GSR-T's Avatar
I always wanted to try to use my FTS but for some reason it seems like it wouldnt be very easy of drivetrain parts......
anybody reading this that has actually used it? is it really worth it? seems to me to just be a crutch for a slow shifting driver.
Old Nov 14, 2008 | 09:52 PM
justinCO's Avatar
Default Re: (96 GSR-T)
I used to have FTS on my old Evo 8, it friggin rules. Most the time racers will just floor it and shift while bouncing off the normal rev limiter no? Or use some other sort of mechanism that lowers rpm between shifts.
I'll update when I get it hooked up later.
Justin
wwolf771177
Dec 17, 2013 05:44 AM
97grnrs
Mar 7, 2008 05:31 AM
IN VTEC
Jul 6, 2004 12:35 AM
crx1856
Aug 5, 2003 11:35 PM
Scott - 93HB Si
Aug 9, 2002 10:08 AM
