launch control/ preload / clutch switch problem..
Old Mar 4, 2008 | 05:14 PM
97grnrs's Avatar
Default launch control/ preload / clutch switch problem..
how can i use my clutch cut launch control and still preload a lil for slicks. soon as i let the clutch up a hair launch control kicks off cause the switch is being released? any ideas?
Old Mar 4, 2008 | 05:18 PM
Turbo-charged's Avatar
Default Re: launch control/ preload / clutch switch problem.. (97grnrs)
we have a special adjustable clutch switch that we use (not for lauch control, but can be used the same)
you just have to make a bracket to mount it.
another option is to put the arming switch on your e-brake.
most computers have lauch controll based off of VSS as well, thats obviously the easiest.
Old Mar 4, 2008 | 05:56 PM
97grnrs's Avatar
Default Re: launch control/ preload / clutch switch problem.. (Turbo-charged)
i suppose i could set it up to work on the ebrake pinswitch.. as long as i get the ebrake fully down before i have to shift it should work
Old Mar 6, 2008 | 06:00 PM
97grnrs's Avatar
anyone know what the blu/blk wire on the starter relay is ? just a ground when clutch is down or a power? just wondering. i may try to hook launch up to ebrake switch
Old Mar 6, 2008 | 08:31 PM
streetracer6rpt's Avatar
slipper clutch?
Old Mar 7, 2008 | 05:31 AM
97grnrs's Avatar
Default Re: launch control/ preload / clutch switch problem.. (streetracer6rpt)
act 6 puck unsprung. reg clutch
wwolf771177
Dec 17, 2013 05:44 AM
fryman
Sep 28, 2011 05:47 AM
efyou
Oct 9, 2007 01:54 PM
binarypunk
Sep 24, 2007 06:04 PM
