4 bolt with A/C...
Old Nov 13, 2008 | 12:32 PM
Trojan Man's Avatar
No Sales Forums
From: Reading the Chronicles and Blowin Trees in Virginia
Default 4 bolt with A/C...
...Is it possible? I found a turbo I want but I dont want it if I cant use it with A/C.
Old Nov 13, 2008 | 12:38 PM
spoolie's Avatar
Default Re: 4 bolt with A/C... (Trojan Man)
i dont understand?? doesn't the manifold dictate the placement and a/c compatibility?
Old Nov 13, 2008 | 12:45 PM
tony tone's Avatar
GDD Moderator
your manifold is what you need to worry about when it comes running a/c.
for example, i have a custom td autowerkes a/c compatible ramhorn manifold:
sorry for the large pic but it's all i have. also, the hose looks closer than it really is.
Old Nov 13, 2008 | 12:47 PM
Trojan Man's Avatar
No Sales Forums
Default Re: 4 bolt with A/C... (tony tone)
Would a inline pro manifold work?
Old Nov 13, 2008 | 01:06 PM
tony tone's Avatar
GDD Moderator
any pics of the manifold in question?
Old Nov 13, 2008 | 02:48 PM
carrnut21's Avatar
it is possible, just not easy. I did it with a revhard cast manifold, garrett t3/t4 and a 3 inch downpipe. Compressor was on the passenger side. had to shave the block webbing to get it all to fit, but it works. car still has working A/C, although the dp cooks the compressor if you sit traffic to long when its hot
oh yeah car is an 00 GSR with a B18C
edit: will try to find pics later
Old Nov 13, 2008 | 03:05 PM
Turbogixxer's Avatar
No, it would not. It has to be a 5-bolt.
Old Nov 13, 2008 | 04:26 PM
AdamB18C1EK's Avatar
Default Re: 4 bolt with A/C... (Turbogixxer)
x2. their t3 manifold and a 5bolt.
Old Nov 14, 2008 | 08:11 AM
TheShodan's Avatar
Moderator
Default Re: 4 bolt with A/C... (AdamB18C1EK)
Unless you get the INLINE PRO 4 bolt variant.
Old Nov 14, 2008 | 08:22 AM
totsie7944's Avatar
Default Re: 4 bolt with A/C... (TheShodan)
To the OP, if you want to keep your AC you need to focus on the manifold first. Full-Race and Neukin make AC compatible manifolds as well as a few others. As for turbos, the largest you will be able to run to my knowledge is a GT3582R
Old Nov 14, 2008 | 09:20 AM
dpetro1's Avatar
Default Re: 4 bolt with A/C... (totsie7944)
i think the OP needs to reword the question. he wants to know...
can a 4-bolt turbo work with a log mani in A/C configuration.
basically no unless you use the inlinepro 4-bolt mani
http://www.inlinepro.com/catal...d=134
Old Nov 14, 2008 | 11:33 PM
airwalk07143's Avatar
Default Re: 4 bolt with A/C... (dpetro1)
I happen to have an inline pro ac/ps turbo kit with a sc6031 for sale if your interested pm.
JonySoprano
Sep 11, 2009 06:14 PM
crazy_eddy
Jun 11, 2006 05:26 PM
twisted civic
Aug 13, 2005 08:46 PM
Charles B.
Feb 18, 2004 11:23 AM
