b16 ek
Old Nov 12, 2008 | 01:27 PM
OoAoO's Avatar
Default b16 ek
i plan on putting a b16 in my ek what mounts can i use it is out of an si but there are no mounts with it i have the t bracket but what else do i need
Old Nov 12, 2008 | 01:33 PM
ekb16's Avatar
mounts and brackets from the 99-00 si
Old Nov 12, 2008 | 01:40 PM
turbo97coupe's Avatar
Default Re: (ekb16)
u dont need all the mounts and brackets . just need the 99-00 si rear T bracket and the two prong cast iron mount that bolts to the block on the timing belt side then use the rest of your stock mounts and brackets . and then you need DC shift linkage and SI or DC axles and half shaft . i just did a B20/vtec swap in my Ek so i know for a fact what i just listed works . its exactly what i used so goodluck
Old Nov 12, 2008 | 01:42 PM
Default Re: (ekb16)
Old Nov 12, 2008 | 01:47 PM
OoAoO's Avatar
Default Re: (turbo97coupe)
thanx i thought so but wasnt sure the cast piece is still on the blosk so im good and like i said i have the t bracket
Old Nov 12, 2008 | 01:49 PM
Default Re: (OoAoO)
your good then . throw it in and then post pics lol
https://honda-tech.com/zerothread/1998336
go there if u have any problems just scroll down to the swap information section in the first post and use the B20 into ek parts list or swap guide not sure how many swaps uve done. this was my 8th b swap so it was cake but goodluck
Old Nov 12, 2008 | 04:22 PM
OoAoO's Avatar
will the si linkaga work
Old Nov 12, 2008 | 05:29 PM
94EG8's Avatar
Seagull Management
Default Re: (OoAoO)
yes
Old Nov 12, 2008 | 05:30 PM
sintype's Avatar
Originally Posted by ekb16
mounts and brackets from the 99-00 Si.
yep.
Old Nov 12, 2008 | 05:51 PM
OoAoO's Avatar
Default Re: (sintype)
as i said b4 i have no si mounts i only have the t bracket and the cast piece by the timing belt
Old Nov 12, 2008 | 06:42 PM
Default Re: (OoAoO)
thats all you need man i promise you ! you can also use ALL the si **** if u want to waist the money but to do it the simple way u only need the block mount on the timing belt side and the t bracket . then use the rest of your D series mounts and brackets ! its in the FAQ for christ sake exactly what i just told you lol i dont know why these guys keep saying you have to you ALL si brackets because thats FALSE !!! my B is in my car running driving and sitting perfect with what i just listed take my word
heres str8 from the FAQ !
B swap mounts for EK
’99-00 Civic Si rear mount bracket ( T-Bracket )
B-series swaps into 96+ Civics you need a ’99-00 Civic Si timing belt mount bracket.( the cast peice bolted to the block)
The front lower driver’s side torque mount bracket that comes with The del-Sol VTEC (if you want a/c iam not using any torque mounts on my B20/v .)
Reuse all other civic mounts and studs. Just replace the above brackets
thats all str8 from the FAQ again goodluck man
Old Nov 12, 2008 | 07:23 PM
OoAoO's Avatar
ok thanks im just tight on cash and im selling my turbo d for and using the money to buy a b16b and i wanna make sure i dont need anything else
Old Nov 12, 2008 | 07:58 PM
Default Re: (OoAoO)
nah man u need whatever ecu your gonna use the shift linkage and axles and half shafts and your good u already have the mount part str8 what years your ek ?
Old Nov 13, 2008 | 09:01 AM
honda_hackett's Avatar
so you dont NEED the driver side torque bracket? unless you run a/c cuz i jsut did a gsr swap into ek and finishing wiring but my budy was saying i needed it. (im no a/c)
Old Nov 13, 2008 | 02:33 PM
Default Re: (honda_hackett)
nope u dont need it iam running 450whp in my 97 coupe with no torque mounts at all and all factory integra motor mounts and its fine i only have 7 dollars energy suspension motor mount inserts in the stock integra mounths but no torque monts in it . and in my ek sedan that i just did the 213 whp B20/vec swap in iam running no torque mounts with only stock mounts with inserts too and its fine those are both daily drivers though . solid mounts and stuff are mainly for race cars that need ZERO engine movement .if u use the soft mounts u will have zero cabin vibration , so dont worry about the torque mounts ive never ran torque mounts in all 8 of my B series swaps i have done
Old Nov 13, 2008 | 09:11 PM
OoAoO's Avatar
i have a 99 what teg mounts i only have the stock ek ones
Old Nov 14, 2008 | 07:29 AM
Default Re: (OoAoO)
u dont use teg mounts u use the 99-00 rear t bracket and then the 99-00 si 2 prong cast bracket that bolts to the block on the timing belt side then u use the rest of your factory EK mount an brackets only use integra shift linkage axles and half shaft . or u can use the SI shift linkage half shaft and axles
Old Nov 16, 2008 | 02:58 PM
JDM'dinMD's Avatar
Yeah you only need the si t bracket and the timing side other than that you dont need any other
jdm as fk
16
Jan 22, 2010 08:49 AM
ViSiONxBoY
19
Aug 8, 2009 04:37 AM
ek82
30
Feb 4, 2006 05:43 PM
ek82
Dec 11, 2005 01:27 PM
92eg6
May 29, 2004 08:23 AM
