lowering the prelude a little
Old Nov 11, 2008 | 09:59 AM
teambk8's Avatar
Default lowering the prelude a little
I have 4th gen with stock suspension and after the years it def needs to be replaced! I wanted to lower the car a tad but no more than an inch. I was thinking like 1/2 and inch in the front and 3/4 of an inch in the back. Besides driving around with a car full of fat ppl how can I achieve this? A lot of the adjustable coilovers seem to do a lot more than this OR they will only go to a min of 1 inch. I have heard of ppl using spring clamps to compress the springs a little for a cheap way to achieve this. Any advice?
Old Nov 11, 2008 | 11:48 AM
viper_boy403's Avatar
I'd go with some Tein S.techs or H.techs for just a moderate or small drop, respectively
Old Nov 11, 2008 | 06:04 PM
snobordboy's Avatar
Moderator
If you like how the springs ride now, but want a lower look, just get some Koni yellow shocks, they have adjustable levels for the spring perch, and better control to boot! I added them to my car which Had Neuspeed Race springs on stock shocks, controls the shocks way better than before, and I dropped it another inch or so using the perch slots. I actually went too low and need to raise it back up, 4 inchs lower than stock is no fun, especially on Canadian roads!
Old Nov 11, 2008 | 06:08 PM
twiztid00002's Avatar
Default Re: (snobordboi)
i dont think stock springs will fit on koni's.. will they?
Old Nov 14, 2008 | 12:01 PM
teambk8's Avatar
Default Re: (twiztid00002)
yeah if I could control the drop with the spring perch rather than the spring itself that would be ideal. Anybody know if the konis will fit on stock springs?
Old Nov 15, 2008 | 08:24 AM
m00nr0ck Si's Avatar
Default Re: (teambk8)
Get some Tein Stechs.....and tokico blue shocks/struts....I have the tokicos and sprint springs and Im very happy with the ride......
BTW- dont use any kind of spring clamps....my buddy had them on his tiburon and one came loose while driving and the car got all crazy while going 70 mph.....
Old Nov 15, 2008 | 10:40 PM
Kronn 98SH's Avatar
Default Re: (m00nr0ck Si)
what? you mean I shouldn't use duct tape in place of a hood latch?
Old Nov 16, 2008 | 03:15 AM
mattsnooz's Avatar
Default Re: (Kronn 98SH)
no man....the duct tape was for the 1) holes in tires, and 2), the exhaust leak at your flex pipe.
Oh, and to wrap around loud quacky duck's beaks!!
Old Nov 16, 2008 | 10:27 AM
NOSUUR93's Avatar
go with good sping strut combo youll be happy
Old Nov 18, 2008 | 06:08 PM
prelude_93vtec's Avatar
Just cut the stock springs a little bit..
Old Nov 18, 2008 | 06:13 PM
Icon3
or dont cut the stock springs a little bit
A Blue Lude's Avatar
H-techs will lower it a little less than an inch and have OEM style spring rates
Stock springs on Konis, lower perch, will be pretty similar although you'll have the bumped up damping of the Konis (it won't ride bad or anything, but it is more aggressive).
Old Nov 19, 2008 | 01:56 PM
teambk8's Avatar
okay cool, nobody has ever used clamps on the stock spring to slightly compress them. I am really looking for a cheap, slight, lowering option... I know I can do a full suspension set up with all the great aftermarket brands but I don't really wanna lower my car THAT much nor my bank account THAT much. I might just keep the stock height and live with it rather than do a full suspension set up for a DD
Old Nov 19, 2008 | 06:58 PM
as others posted,, tein s-techs or h-techs would be a good way to go. like 100-200 dollars... if thats not cheap enough then start savin for some gas :thumbsup:
whitehf
Jan 20, 2009 10:40 AM
Fongman
Apr 22, 2007 02:47 PM
CivicHP
Suspension & Brakes
Aug 21, 2006 08:36 PM
StanBo
Jan 23, 2002 03:50 PM
