94 Civic Coupe No Heat!!!!
I have checked all fuses and thats not the problem. When I change the settings on the climate control I can hear the dampers moving but no air is being blown out. Winter is coming and it's kind've hard to go without heat. If the blower motor is bad is there a way to test it? Thanks.
Does your fan run? check all speeds. If you have only high speed then the resistor pack went out its on the blower motor housing. If you work the switch back and forth and can get it to turn on or hitting the dash causes it to work then more then likely its the fan motor switch in the climet control. Its a little harder to change out but when they fail its on min you have a blower running the next thing you don't
how do i go about removing the switch? Or checking to make sure thats the problem. But I'm getting no air at all, no defrost or anything.
what year car? 92-95 remove your radio, then the bezel around the climate control.
the wiring harness is very short and hard to get the wiring harness plugs unhooked and plugged back in just take your time and be careful. take a look at the top left of the unit when my switch went bad the plastic here melted a little and it was discolored.If this had happened you might have to pry a little on the switch to get it loose from the housing. reinstall is the revs of removal
So I have the bezel around the climate control out. Should I simply unscrew the climate control box and bring it out. And the switch is a clip on the back?
yea. it fits n a groove that allows the cable to slide in and out of an outter rubber cable thing. there is a clip over that. if there isnt one its broken and i used epoxy to hold mine in place
I got the entire dash piece off, stereo out, and there is a god damn screw on the bottom of the climate control that just wont [freak]ing come out. I sat there and turned it for 45 mins.
Mistermark
14
Aug 27, 2006 10:40 AM
crxvtecturbo
Dec 24, 2004 10:18 AM
