Getting >100% duty cycle on 550's!!!!
Old Nov 9, 2008 | 09:11 PM
willyboyK20's Avatar
Default Getting >100% duty cycle on 550's!!!!
I need some one to take a look at my map and datalog,
setup is
t3/t04e 50 trim w/.48ar
walboro 255 intank
rc sat 550's
Spoolin manifold, 2.5 inch down pipe
3inch exhaust no cat.
Boost is at 10.7 according to crome pro.
12-12.6 afr's
I have fuel pressure gauge in the engine compartment. I need to have someone check it when i go to the dyno next weekend. Maybe the pump is taking a **** a high rpms but wouldn't that make it go super lean?
I last dynoed at the same boost level and made 240 with the full catback attached.
I know 550's should be good for 350-380hp right?
I have the bin and datalog if any tuners can help a fellow tuner out.
Old Nov 9, 2008 | 09:23 PM
98vtec's Avatar
moderator emeritus
Default Re: Getting >100% duty cycle on 550's!!!! (willyboyK20)
the Crome duty cycle values are not correct.
does the AFR start to lean out?
Old Nov 10, 2008 | 09:31 AM
xenocron's Avatar
I've run RC550s to about 425-450 before (52 psi base pressure).
Most programs duty cycle numbers are "reasonably close" at best.
Old Nov 10, 2008 | 02:34 PM
inspector01's Avatar
Sorry for hijack, but i know on the table they are only approximations, but when you datalog and it records a duty cycle, is that correct??
I have been helping a friend with an ITR, S300, RC 750s, and a GT28 and Im getting datalogs showing 100% duty cycle (and the table approximates that as maxing them out) at 13-14 pounds, which shouldn't be anywhere near maxing out those injectors. I am running it rich (high 11s in this area) but still, not overly rich.
Also, to get the fuel right at idle, i set fuel compensation for 625 cc injectors, so i don't know if that causes it to calculate differenly.
Old Nov 10, 2008 | 05:49 PM
Default Re: Getting >100% duty cycle on 550's!!!! (98vtec)
ohh, i didn't know that.
It does start to lean out a touch right around redline to 12.6-12.7.
jdmdc529
Feb 12, 2009 04:35 PM
b20turboic
Nov 19, 2003 01:53 AM
99lspwr
Oct 24, 2003 09:12 AM
tampabud
Jun 25, 2003 10:41 AM
TurbothisLS
Jan 2, 2003 03:43 PM
