what to do
Old Nov 9, 2008 | 05:09 PM
civicsi18's Avatar
Default what to do
ok so i am about to get hondata for my 99 si and i dont know what ecu to get because i here everyone gets the p28 and put hondata on that, why cant i put it on my p2t and what is the best ecu to get cause i hear that some ecu's make VTEC "hit harder". thanks for the help
Old Nov 9, 2008 | 05:38 PM
z6hatchboy's Avatar
The problem with the p2t is that its obd2, and that makes it difficult. I cant remember if hondata supports that or not, i know crome doesnt. The reason everyone uses p28 is because they're obd1, you'll need a obd2 to obd1 jmper harness though, and since yours is a 99' its obd2a. VTEC will NOT hit harder with any ecu, its simply either in or its out.
Old Nov 10, 2008 | 03:43 AM
00b20vtecoupe's Avatar
Default Re: (z6hatchboy)
like he said u cant use ur ecu b/c its obd2. everyone uses p28's b/c they r the most common they can be found in any 92-95 civic ex or sohc vtec hatches. you can also use the obd1 gsr ecu. and like he said ull need a jumper harness for obd2 to obd1. be prepared to not be able to pass inspection b/c its not ur stock cpu and u r no longer obd2.
Old Nov 10, 2008 | 04:33 AM
wrenchez81's Avatar
Default Re: (00b20vtecoupe)
^^^ X3!!! in my opinion the p72 obd 1 ecu is the best ...be careful tho there are obd2 variants of the p72 aswell... and say to any hopes of passing a smog test!!!
connor53
Engine Management and Tuning
Oct 5, 2008 02:15 PM
wesley_925
May 15, 2008 05:11 PM
egbaby
Mar 1, 2008 06:52 AM
HondamanXxX
Aug 10, 2007 10:27 PM
otakueric
10
May 22, 2004 06:07 PM
