Parking brake light comes on on Hard turns? Just need a adjustment?
Old Nov 9, 2008 | 11:30 AM
supermotothud's Avatar
Default Parking brake light comes on on Hard turns? Just need a adjustment?
On hard left turns the parking brake light comes on.
also this morning after i disengaged the parking brake the light still remained on .
Therefore causing the ABS to disable.
Is the parking brake in need of a adjustment?
or would it be the switch that tells if its up or not?
Old Nov 9, 2008 | 11:37 AM
P_Adams's Avatar
Default Re: Parking brake light comes on on Hard turns? Just need a adjustment? (supermotothud)
I'd first check that you've not run out of brake fluid. I believe the fluid level sensor shares that indicator.
The parking brake reminder function does nothing more than indicate that the control handle hasn't returned to the released position. I don't believe that this (in itself) would effect the ABS.
P
Old Nov 9, 2008 | 03:07 PM
Default Re: Parking brake light comes on on Hard turns? Just need a adjustment? (P_Adams)
Ok I'll check the brake fluid when i get home from work.
but i did recall that to disable the ABS driving with the parking brake up would do that....i dunno where
Old Nov 9, 2008 | 07:44 PM
sony224422's Avatar
def check your fluild. i don't think your abs will be disabled with the light being on, unless your low on fluid. or check for leaks as well
Old Nov 9, 2008 | 08:18 PM
bseriescrxsi's Avatar
he is right your abs will not disengage unless the system itself malfunctions or your dangerously low on fluid or are leaking fluid and the pressure isn't there for it
Old Nov 9, 2008 | 10:48 PM
GlassJAw's Avatar
It may also pay to check your brake pads if there isnt any obvious signs of a leak (low brake pads = caliper pistons out further which also equates to low fluid level)
Old Nov 10, 2008 | 03:17 PM
it was low brake fluid. it was leaking from the ABS modulator. I had recently replaced the ABS modulator. I went in and tighten all the connsections. Hopefully this will fix it and the ABS modulator doesnt leak in the future
Old Nov 10, 2008 | 04:09 PM
P_Adams's Avatar
Default Re: (supermotothud)
Glad we put you on the right track, but there's one other place you should check - the back of the Brake Master Cylinder, where it mounts to the brake booster.
When these start failing, they will sometimes start leaking past the rear piston / shaft seal.
It is most times apparent as a verticle path of desolved paint on the brake booster just below where the Master Cylinder mounts to it.
If this condition as apparent, it bears having it looked at. If left unattended, that leaking brake fluid will damage the Diaphram in the Booster Assembly.
Just a 'heads up'
P
95BG33PGSR
Apr 10, 2011 03:54 AM
mikester_91
Jan 18, 2005 01:14 PM
sushib01
Aug 30, 2004 03:43 PM
thrty8street
Dec 26, 2003 10:10 PM
Hybrid CRX
Jun 6, 2003 08:13 AM
