Type R B18 C ????
Old Nov 9, 2008 | 07:43 AM
h-duced's Avatar
Default Type R B18 C ????
My buddy just put pistons in his B18 and we were wondering if its safe to fire up and drive with a stock tune. He put in JE 12.5:1 compression pistons
Old Nov 9, 2008 | 08:02 AM
Hanmin's Avatar
yeah, just retard the timing, and use the highest octane gas, get colder spark plugs, and a colder thermostat. you want to try to prevent detonation.
Old Nov 9, 2008 | 03:30 PM
h-duced's Avatar
Default Re: (Hanmin)
93 oct or does he need more? And, now that its higher compression do we need to add more fuel? And if so he has stock injectors will that be ok?
Old Nov 9, 2008 | 03:53 PM
tnluder's Avatar
Default Re: (h-duced)
It all has to do with preventing detonation.. As it's been stated before --->
Go 2 heat ranges lower on the plugs. PFR6G-11 is the stock plug, go with a PFR4G-11 if it exists and you want to stay with the platinum plugs...
Old Nov 9, 2008 | 04:09 PM
h-duced's Avatar
Default Re: (tnluder)
Ok sounds like a plan. What should I gap the plugs at and how much should the timing be retarded? Got stock cams but do have AEM adjustable cam gears also which ones do we retard exhaust or intake or both? Last but not least who makes colder thermostats and where could I find one of them at? I now understand that high octaine is needed does it have to be 104 or can we get away with premium 93oct pump gas
Old Nov 9, 2008 | 07:06 PM
h-duced's Avatar
Bump skeet skeet
Old Nov 10, 2008 | 12:39 AM
sr20hardbody's Avatar
i'd try premium with some octane booster and you shouldnt have to change the fuel requirements since bumping compression creates a more effecient engine so if anything you should be using less fuel.
Old Nov 10, 2008 | 06:05 AM
Hanmin's Avatar
oh yeah, have the spark plugs gapped less than stock, don't know exact measurements, look at other motor compression ratios/gap. i hope this is temporary.
Old Nov 10, 2008 | 06:47 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (sr20hardbody)
To prevent detonation, you'd have to use more fuel.
OP...your stock injectors will probably be fine. I wouldn't beat the crap out of the car with the stock tune and injectors...but for the sake of driving somewhere to have it tuned, I think you'll be fine. Don't beat on it. Don't drive around like that for too long.
Old Nov 10, 2008 | 08:57 AM
00b20vtecoupe's Avatar
Default Re: (B serious)
yea 93 octane is fine but i would get that tuned asap. and colder plugs are not platinum use copper. they r like 2 bux a plug. but wat motor is it, a b18 wat?
Old Nov 10, 2008 | 08:58 AM
Default Re: (00b20vtecoupe)
by the title im guessing type r ?
Old Nov 11, 2008 | 06:40 AM
h-duced's Avatar
Yeah its a type r
sneakychaos
Nov 8, 2008 04:47 PM
em1si
Sep 3, 2007 12:23 PM
KYSI
Jun 2, 2006 06:11 AM
Qwikrex
11
Jan 20, 2003 11:52 PM
