Main Relay?
Old Jul 30, 2002 | 06:00 PM
1stealthls's Avatar
Default Main Relay?
My friend has a 92 civic lx that won't start. The motor is getting spark, distributor (igniter and coil) is good, check all fuses, any suggestions maybe a main relay????
Old Jul 30, 2002 | 06:30 PM
BERT-O's Avatar
Default Re: Main Relay? (1stealthls)
yep, a common on all hondas.
try this:
insert the key in the ignition, turn the key on without cranking the motor.
listen closely as you may here the fuel pump kick in.
it should sound like a deep hum and a light click. should last only for a few seconds.
if you don't hear it, chances are the main relay.
this method is one way without go to a local mech charging a few to check everything.
if not, suggest someone certified mechanic to look at it.
good luck
[Modified by SANBST, 10:32 PM 7/30/2002]
Old Jul 30, 2002 | 06:36 PM
DelSol808's Avatar
Default Re: Main Relay? (SANBST)
did you try swapping the relays?? that might help you solve your problem
Brand
21
Sep 8, 2022 09:39 AM
collkid
13
Sep 16, 2015 09:10 PM
glpalmer
Jul 13, 2015 06:50 AM
redcivic13
Sep 29, 2008 08:50 PM
silvan
Aug 13, 2003 12:28 PM
