Main Relay?
Main Relay?
My friend has a 92 civic lx that won't start. The motor is getting spark, distributor (igniter and coil) is good, check all fuses, any suggestions maybe a main relay????
Re: Main Relay? (1stealthls)
yep, a common on all hondas.
try this:
insert the key in the ignition, turn the key on without cranking the motor.
listen closely as you may here the fuel pump kick in.
it should sound like a deep hum and a light click. should last only for a few seconds.
if you don't hear it, chances are the main relay.
this method is one way without go to a local mech charging a few to check everything.
if not, suggest someone certified mechanic to look at it.
good luck
[Modified by SANBST, 10:32 PM 7/30/2002]
Brand
21
09-08-2022 09:39 AM
collkid
13
09-16-2015 09:10 PM
