FENDER BENDER!!!!!!!! need help....
Old Nov 8, 2008 | 06:21 PM
HyRev's Avatar
Default FENDER BENDER!!!!!!!! need help....
.....so the gist of it is about 2 hour ago my friend calls me up to go outside, he was gonna help me with my alternater belt sqeaking problem i was having so i go out side (by this time it was already dark) and i go to open my drivers side door and i hear a huge snap, so i close my door and sure enough my fender was completely smashed in!!! i was Fu<ken pissed espesically since i had jus got new fenders from PASSWORD:JDM a few weeks bak.... ok so my question is, i still have my stock fender frm before but i dnt have anything to cut into it with(to install my side marker).... so wht would i need to cut into the fender to make it look decent?????
(will post pix tmrw)
Old Nov 8, 2008 | 06:35 PM
z6hatchboy's Avatar
Use a dremel, go to my threads. I have a DIY write-up using a dremel installing side markers
Old Nov 8, 2008 | 07:23 PM
Unseen Racer's Avatar
Default Re: FENDER BENDER!!!!!!!! need help.... (HyRev)
sorry to hear that bro
Old Nov 8, 2008 | 07:37 PM
doubleoazn03's Avatar
Default Re: (z6hatchboy)
i agree with z6hatch. its easy, get a dremel and some templates from honda-tech and just cut accordingly. I've done 2 sets of civic fenders and 1 set of integras.
good luck
Old Nov 8, 2008 | 08:14 PM
slo_hatch's Avatar
Default Re: (doubleoazn03)
make sure you dont cut the holes too big tho. make a template from your pw:jdm fenders out of cardboard and cut the other hole to match exactly. thats what i would do...
Old Nov 8, 2008 | 10:16 PM
mattyv's Avatar
Click here if you have 96-00 civic https://honda-tech.com/zerothread?id=1928843 and here http://members.***.net/ninety2...r.htm if you have 92-95. it will explain everything you need to know
Old Nov 8, 2008 | 10:21 PM
slo_hatch's Avatar
Default Re: (mattyv)
but if he already has the other side done...he will want to make sure he gets them the same again.
OP: like i said...get a piece of cardboard and measure from the good side (from the door to light, bottom of fender to light, top of fender to light, and from the headlight to light.) make sure they are the same and make sure your light lines up straight and take your time. i didnt take my time and messed up a fender. there really isnt a certain place to put them...but it would look funky if you had one in one spot and the other in a different spot.
Old Nov 10, 2008 | 11:51 AM
ek4_b16a's Avatar
Default Re: (slo_hatch)
if you can't afford the dremel, just to go to your closest radioshack and buy a metal nibbler...about $15
dayvid05
Aug 5, 2008 01:54 PM
s9000supratt
Jul 31, 2008 02:45 PM
babes 99 GSR
Jun 24, 2003 12:13 AM
SL!M
Jun 5, 2003 12:12 PM
