Brakes anyone?
Old Jul 30, 2002 | 05:40 PM
Kellindal's Avatar
Default Brakes anyone?
Dumb question but...
I've seen some people post about Brembo blanks. Are those just pads? I'm just thinking that I'm gonna need new brakes in the future, and I figure, if I have to replace stuff, why not upgrade it while I'm at it. So are Brembo blanks, is that a new brake kit, as well as blanks for the pads? Or is it just the pads. What are some recommendations for brake kits? I've heard Fastbrakes is a good kit? Any input is appreciated.
Old Jul 30, 2002 | 05:42 PM
StyleTEG's Avatar
Default Re: Brakes anyone? (Kellindal)
brembo blanks are replacements for the rotors, not the pads.
They are high quality, and pretty cheap too.
Old Jul 30, 2002 | 05:44 PM
bryan305's Avatar
The blanks are just regular rotors. If I were you, I'd pick up a set of the slotted ones that are usually on groupbuy for ~$60 a pair. To go to a bigger rotor, either fastbrakes or aem. HTH
Old Jul 30, 2002 | 05:48 PM
Kellindal's Avatar
Default Re: Brakes anyone? (bryan305)
Bare with me, I know jack about brakes. Can someone give me a breakdown on the braking system? What parts are involved. How everything works together? How do the Brembo blanks rotors improve braking? What's a good pad and caliper upgrade?
One the side, I've heard slotted rotors aren't good, and I've heard the AEM's are terrible.
Old Jul 30, 2002 | 06:45 PM
StyleTEG's Avatar
I don't beleave in slotted or cross-drilled brakes on daily drivers.
The slots and drills are used to vent brake gases that build up between the brake pads and the rotors. That gas is extremely hot and will increase brake fad, and can cause glazing. Though this only becomes a problem under heavy braking, and daily driving rarely gets to this point.
Sloted and crossdrilled/drilled rotors are good if you see track time (not so much autoX, since you are going in short runs) then you may want to look into them. Otherwise stick with the blanks, as the other rotors (drill, sloted, etc) have been known to have problems with warping, cracking, etc
Old Aug 1, 2002 | 05:08 PM
Kellindal's Avatar
Default Re: Brakes anyone? (StyleTEG)
What about replacement calipers and pads? Or are those unneccesary? Yeah I have a daily driver, and I understand the point of slotted rotors, I meant I heard they weren't good for daily drivers, like the application I would want. There just unnecessary.
But what about calipers and pads?
Old Aug 1, 2002 | 05:12 PM
Chris's Avatar
No reason really to upgrade rotors and calipers.
The best, most noticible, least expensive upgrade will be Pads.
The only reason I could see upgrading rotors and calipers is if you have alot more horsepower than stock, and have "out-powered" the braking system.
Pads will have the most dramatic effect.
Call me! you still in town?
Old Aug 3, 2002 | 03:53 PM
Kellindal's Avatar
Default Re: Brakes anyone? (Chris)
Yeah I'm still in town until mid-September. I'm just wondering about it because I think my rotors may already be in bad shape. There's a slight shaking when I apply the brakes coming to a stop. I was just wondering what I should look into when I got around to it.
Old Aug 3, 2002 | 09:23 PM
Tweakmeister's Avatar
versus having your rotors turned (they make them striaght again to prevent the shaking from being warped).... you could just buy some brembo blanks since when you turn rotors you're taking away how much heat they can hold (which means they could crack, etc.)
for pads I'd suggest Axxis Ultimates. one of our board sponsors (don't know if they still are) actually has great prices on them...
http://www.cobaltfriction.com/prod-c...pads_axxis.htm
Old Aug 3, 2002 | 09:46 PM
Padronis's Avatar
Brake pads no longer create these gases that you speak of. That is a problem that cars had a long time ago. Slotted and cross drilled rotors are ok for a street vehicle, but not so good on a race car. I recomend some either stock rotors, if you won't be autoxing or roadracing, or Brembo blanks from http://www.collettimotorsports.com and the Axxis Ultimates that Tweakmeister said. I have the Brembo blanks and Axxis Ultimates and I am very happy with it.
Old Aug 4, 2002 | 02:16 AM
GSRaCeRbOI's Avatar
Default Re: Brakes anyone? (G2LSS)
I have Brembo blanks and Hawk hps pads. I'm happy w/ my setup.. might try the axxis ultimates next time around.. I got my stuff from colletti too
Old Aug 4, 2002 | 05:32 AM
StyleTEG's Avatar
Not that I don't beleave you, just trying to find the right information. Even if they don't create gas they still dust. The dust is going to build up between the pad and the rotor and it will reduce contacting surface between the pad and the rotor. Vents/slots would vent the dust still lodged between the pade/rotor.
Again, not necissary for street use.
If the slots/drills are not good for race applications, why does porsche still use em on their 911's?
Old Aug 4, 2002 | 06:24 AM
4doorRS5spd's Avatar
New User
Check out this very informative article about the braking system, rotors in particular.
http://www.stoptech.com/whitepapers/...otors_myth.htm
_______
Old Aug 4, 2002 | 11:03 AM
Padronis's Avatar
I really couldn't tell you why Porsche uses cross drilled rotors, butthere is a difference in how they were made. Most (not sure how many) aftermarket crossdrilled rotors were drilled after they were made. This reduces the strength of the rotor. I f you were to race with these, you almost definately crack a rotor. This is mainly due to the fact that there is not enough material ( becasuse it was drilled out) ,and the fact that heat builds up more where there are rigid edges (around the drilled holes). The rotors that posche or Ferrari uses, were most likely designed with the holes in them. The rotors are a little thicker (to compensate for the loss in matetrial from the holes), the rotors are cast with the holes in them, and the edges of the holes are beveled.
Old Aug 4, 2002 | 06:29 PM
StyleTEG's Avatar
Again, I see what you are saying but I am still not so sure. It makes sense, but I don't see why porsche would put them on a GT2 (which is pretty much a straight track designed car stock) if you were going to crack a rotor racing them.
Also, many years ago my dad drove his 911 on a track for several hours of heavy braking with out any rotor problems. Talking to him about it today, he did say he had to replace the brake pads soon after but the stock rotors were on the car the day he sold it.
commotion
19
Feb 28, 2009 02:55 PM
standbackimapro
Sep 21, 2007 11:27 AM
xanatoes
Jul 25, 2007 12:48 PM
skimeast1982
Oct 18, 2006 04:31 AM
89Si
Jul 2, 2002 04:39 PM
