Brembo Rotors?
Brembo Rotors?
Is there a noticable change in stopping power when upgrading rotors and pads?
Or is there only a gain when upgrading everything ( calipers, rotors, pads)
I was thinking about getting some brembo drilled rotors, with hawk pads or somthing like that, but im not looking for looks, will it stop any better?
Re: Brembo Rotors? (standbackimapro)
Some steel braided brake lines will give you the most noticeable improvement, not in stopping power, but in stopping response, if you don't intend to get a good big brake kit. However, don't worry about bigger brakes unless you've got a pretty fast car anyway. What's your power/powerplant?
Going from worn rotors and crappy pads to Brembo blank's (slotted) and AEM pads made a world of a difference.
Unless you plan on making your car a track ( or show) car, there really is no reasonable use for big brake upgrades (larger rotor, bigger caliper) A good set of OE sized rotors and performance pads will do you just fine on the street.
Although, steel braided lines are a nice upgrade for the weekend warriors at the track, darg racing and autocrossing.
Re: (97Ej6mike)
Brembo Blanks and Hawk HP's are fine for street applications. I run those in the front and rear and have all new steel braided along with a GSR master cylinder and an Si prop valve and my brakes are better than the stock setup with drums in the rear.
I have great stopping power on the street and this setup has lasted a few Auto X rounds by me. Good luck with whatever your setup is.
Re: (Steezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi »</TD></TR><TR><TD CLASS="quote"> However, don't worry about bigger brakes unless you've got a pretty fast car anyway. What's your power/powerplant?</TD></TR></TABLE>
X2
X2
dragonkx
13
06-29-2010 07:37 AM
H2290
10
07-28-2006 01:56 PM
prostreetonline
06-08-2005 09:52 PM
