Opening hood with a screwdriver? (broken cable)
Yeah so my cable **** out on me today... I did a search and seen alot of relocations, alot of hoods not closing but not alot of hoods being stuck with broken cables, AND explaining how to get the hood open.
I know it involves a screwdriver and getting underneath the car I just dont know where to go from there. I can get a flat head between the hood and get the safety release up, but the lock itself I have no clue. Thanks for any info as its the first time its happened to me..
Originally Posted by 95vxtealhatch
the cable routes next to the drivers side wheel under the fender, i suggest you cut the cable open and pull the latch that way.
after i posted this my power went down for 5 + hours... Thanks for the response.I actually was working on my car aside from that and rolled it back in neutral only to hear a wierd sound and look to find that somehow my tire snatched up the cable and snagged the **** out of it. Pretty much shredded one portion of it. I was able to pull it back into place and ghetto rig it. But i did order a new one already. I think i will just relocate it now...
plus i heard of peole ripping the mud guard away, taking some bolt cutters, and a pair of wire strippers to pop peoples hoods and jack **** from them.....
Originally Posted by i drive a honda
funny you say that same **** happend to me. i rerouted mine in with the wire tuck i did, it kinda goes with the frame rail/ where the upper half where its boxed, pull the fender you'll see LOL
Well they're in for a world of surprise if they pop my hood looking for stuff...chase aka chasebays took care of me in that department!
wow...are you serious??? It doesnt even route that low though...Insane..
nice, supperised to see a mil-spec wiring harness?
Originally Posted by solattack77
quite being honest Dave, just a b my ***. just rig it so you can do it with an alarm fob
Okay, I realize this is old, but hopefully it can help someone. Here is the easy way that takes less than a minute (it took me 15 minutes today to figure it out). Did a radiator on my gf's 00 coupe on Wednesday, was checking fluid today and hood wouldn't open. Latch cable had detached from latch.
You need a flashlight and a Looooong stiff instrument (I used a round metal file about the diameter of a PH2 screwdriver shaft).
Facing the car, go in from the top right side of the Honda emblem. You should be able to see the moving part of the latching mechanism on/near the right. Push it slightly back and to the left while lightly lifting up on the hood. Voila.
sidewayz
Mar 12, 2003 07:28 PM
