Wheel bearing help!
Old Nov 7, 2008 | 10:22 PM
95BoostedEJ1's Avatar
Default Scary Feeling :(
ok i was coming home from the track tonight and me my buddy and my lil brother was playin around on the way home..we was on the bypass goin around 60-70 when i took off (got on it ) and got up to bout 100 the car went into a JERK like felt like my wheel was bout to come off and started pullin really bad to the right..any ever had anything close to this problem? think it could be a bad wheel bearing? imma yank the wheel off 2morrow and see if i can see anything or move anything around..any suggestions
Old Nov 7, 2008 | 10:28 PM
halocore's Avatar
Default Re: Scary Feeling :( (95BoostedEJ1)
are you sure it wasn't just vibration coming from the car. see if it only jerk at 100 or if it jerks in the lower mph speed range also.
Old Nov 7, 2008 | 10:31 PM
lmike6453's Avatar
My main suggestion is not to go more than 85 but you probably already know this.
There are so many possibilities at that speed that I cannot narrow down the problem. Start by checking to see if the wheels are balanced correctly, and then check suspension such as lower ball joints.
Old Nov 7, 2008 | 10:36 PM
no vibration in low speeds.....well i mean i drive on interstates and bypass's all the time..so goin 80+ is sometimes a must when ur in a hurry and such...but somethin makin that vibration at that speed could be dangerous as 60-70mph as well..i mean when i hit 100 car went into a wobble and started jerkin HARD to the right and almost lost control was VERY scary
Old Nov 7, 2008 | 10:46 PM
majinsoftware's Avatar
Defently check wheel bearing, Never had it happen on a honda but on my lancer one wheel bearing started to seize and it pulled to one side quite abit till one day the wheel locked up completely and left a massive skid mark. And it wouldnt turn at all anymore.
My mates car did the same but his wheel came flying off.
Old Nov 7, 2008 | 11:06 PM
jackietreehorn's Avatar
well, i had something like that happen, but my wheel flew off on the freeway and i crashed my eg. i flew into the embankment luckily my crash was broken by those spongy little bushes thats mostly made of water. my lugnuts got loose some how and the spooky part is i just passed over a overpass with a huge drop. heh i know it does not answer your question but reading your post gave me a flash back.....
Old Nov 8, 2008 | 09:06 AM
gonmaro's Avatar
Default Re: Scary Feeling :( (jackietreehorn)
did the car make a moise? like a dry bearing or a grinding? if not, i'd say the tie rods or P.S. rack
Old Nov 8, 2008 | 11:34 AM
cbchotboy's Avatar
same thing happened to me when i drove over messed up roads.. ended up being my tie rods
Old Nov 8, 2008 | 12:53 PM
projectTeG's Avatar
check your axles are they remans?
Old Nov 11, 2008 | 08:13 PM
nope..tie rods are fine..rack isnt leaking..im thinkin pass. wheel bearing..
Old Nov 11, 2008 | 08:39 PM
TegraD's Avatar
Default Re: (95BoostedEJ1)
its your axels... i had this problem about a year ago. change them and it should be fixed... you probley weakened the joints from launching at the trach and after a while the bearings in the boots just got f'd up... it sounds just like my prob. so give it a try
Old Nov 12, 2008 | 06:47 AM
i have a brand new passenger axle and thats the side that it feels funy on..
Old Nov 12, 2008 | 07:18 AM
na+b18c_hatch's Avatar
a buddy of mine had a similar issue. the root of his problem was in one of his front tires. one of the radial belts in the tire was off and it caused his car to pull one way or the other, but not one way in particular. just my $.02
edit: most of the time a wheel bearing (unless it is completely destroyed) will more than likely just make a whirring sound that will get increasingly loud as speed increases.
Modified by na+b18c_hatch at 1:38 PM 11/12/2008
Old Nov 12, 2008 | 09:45 AM
AWD Terror's Avatar
Default Re: (na+b18c_hatch)
Most commonly, a wheel bearing will being to make noise when you turn in one direction while moving. It will get to the point where it will make the noise while going straight as well.
Nothing more you can get from this thread until you jack up the car and have a look around
Old Nov 12, 2008 | 10:13 AM
projectTeG's Avatar
its that axle, im telling you get a better set(with oem inner joints and you will be fine)
Old Nov 12, 2008 | 03:12 PM
well i guess ill call vato zone and see if they can grab me another axle and see if thats the problem..
Old Nov 12, 2008 | 03:38 PM
julianbc2's Avatar
Default Re: Scary Feeling :( (halocore)
my wheel bearing was messed up and it gave off a vibrating grinding noise every time i turned right. so that means it was the left wheel bearing. and while driving it did feel like the wheel was going to fall off
Old Nov 12, 2008 | 05:27 PM
well mine only feels that way when im givin it hell in 3rd and when i hit 4th car goes into a jerk and feels like the wheel is whobblin
Old Nov 13, 2008 | 03:39 AM
i'm telling you bud, check your tires. maybe try rotating them and see if the feeling gets any better. a wheel bearing would more or less just make a humming noise, and it wouldn't be just in 3rd or 4th gear..
Old Nov 13, 2008 | 07:54 AM
its not my tires...it did it on one set of rims i had on it..then i bought a brand new set and it still does it
Old Nov 13, 2008 | 09:22 AM
i see. i know that bad ball joints can make for a very unstable ride at higher speeds...
Old Nov 13, 2008 | 02:14 PM
hmmm
Old Nov 13, 2008 | 06:33 PM
can be ball joints be removed or would i have to buy the whole hub?
Old Nov 14, 2008 | 07:56 AM
if it's the lower i think you can get just the ball joint. for the upper you might need to get the full control arm, but i'm not sure about that.
..speaking of upper control arms, how's your camber setup? adjusted at all? might be another thing to look into-- a good alignment
Old Nov 14, 2008 | 01:49 PM
camber is good..i tried to see if it would jerk again today and it didnt jerk any at all but i only went to 90...but before when i went wide open felt like the lugs were loose and the wheel was gonna come off :S
Unphzd
Dec 17, 2010 01:10 PM
90efSI
12
Mar 11, 2007 08:53 PM
jizno
Nov 23, 2005 01:57 PM
Spike_irl
Jul 31, 2005 06:51 AM
OneThirtyEight
Oct 30, 2001 06:03 PM
