Could a leak in the clutch master cylinder cause gears to grind?
Old Nov 7, 2008 | 08:33 PM
gsr90's Avatar
Default Could a leak in the clutch master cylinder cause gears to grind?
i recently bought a 00 gsr and turns out there's a leak in the clutch master cylinder. There was no grinds at first, but it's been about a month since i bought it and now it grinds here and there at 3rd if i shift fast at 2500 rpm or higher. it feels a little bumpy when i shift it to first sometimes too like it's about to grind. i'm really hoping that the syncros haven't given out. But could a leak cause the gears to grind?
Old Nov 7, 2008 | 08:41 PM
majinsoftware's Avatar
If the clutch isnt fully engaging/disengaging it will cause it to crunch if the revs arnt matched.
Fix the leak first and bleed the lines then you will know.
Old Nov 7, 2008 | 08:48 PM
gsr90's Avatar
Default Re: (majinsoftware)
thanks, i already ordered a oem part and should have it installed soon, as well as switch on the tranny fluid
Old Nov 7, 2008 | 08:50 PM
gsr90's Avatar
Default Re: (gsr90)
now i think about it, it might be that because i also hear the clicking noise every now and then when i depress the clutch pedal
jmeyoung120
Mar 28, 2010 08:53 AM
hspoon
Nov 20, 2006 10:38 AM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
PearlBlueType-S
20
Mar 6, 2006 11:10 PM
bambbrose
Jul 6, 2005 12:46 PM
