SIGNS OF BAD FUEL FILTER???
Old 03-26-2012, 01:20 PM
Jayk00CivicEx's Avatar
Default SIGNS OF BAD FUEL FILTER???
My 1st and 2nd gears seem to be getting a little sluggish, not all the time, just from time to time. Also seems to be getting increasingly more often. Wondering if this may be a sign of clogged fuel filter or what other sources I can check.
Thanks!
Old 03-26-2012, 01:35 PM
Blacknight117's Avatar
Default Re: SIGNS OF BAD FUEL FILTER???
When was the last time you`ve done a tune-up on the car?
Old 03-26-2012, 03:31 PM
redm3turbo's Avatar
Ive seen fuel filters so bad you couldn't blow air thru them and no symptoms from the car. Personally Id look somewhere else, however, if you haven't changed it in the last 30-40k miles, Id change it regardless. They run about 18 bucks aftermarket from a parts store.
Old 03-29-2012, 07:37 PM
Think I will try both... havent had the car a really long time and I am sure a tune up and new fuel filter couldnt hurt.
Thanks Guys!
Old 03-29-2012, 07:44 PM
TOO MUCH TORQUE's Avatar
Thanks Guys!
if youre going to do atune up, do a full one...
spark plug wires, spark plugs(ngk g-powers), cap and rotor, fuel filter, air filter, pcv valve. if youre **** like me, consider changing your coil. and use honda oem parts...aftermarket ignition parts are hit or miss..
Old 03-29-2012, 07:56 PM
Arthas's Avatar
Sounds like a bad cap and rotor, but I would do a full tune up. I highly doubt a fuel filter would cause this, but it would be great to change it.
Old 03-29-2012, 10:49 PM
jdmcertified909's Avatar
i agree bad cap or rotor. but since you werent the original owner i would do a full service to the car.
csckwade
12-28-2012 11:01 AM
coronadrinker
12-18-2006 05:58 PM
Understeer
11-19-2005 07:09 PM
calteg
09-16-2002 04:03 AM
phatintegra
04-01-2002 10:08 PM
Quick Reply: SIGNS OF BAD FUEL FILTER???
