problem with my tach
Old May 12, 2003 | 08:23 AM
Boostless97Lude
Guest
Posts: n/a
Default problem with my tach
the LS tach in my Teggi keeps jumpind around like crazy, i had the distributer off the other day, and it started after i out it back on, so, what did i do to it, how can i fix it?
Old May 12, 2003 | 08:32 AM
Adi Radoncic's Avatar
On Fire!
Default Re: problem with my tach (Boosted97Lude)
If it just started happening the worst that it could be is that its either something with your tach or its a bad ignintor.
If you worked on you car and it started happening its most likely that the ground wire that attaches to the thermostat water neck is off or loose....
Adi
Old May 12, 2003 | 08:47 AM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">the LS tach in my Teggi keeps jumpind around like crazy, i had the distributer off the other day, and it started after i out it back on, so, what did i do to it, how can i fix it?</TD></TR></TABLE>
i have the same problem, except mine only happens when im at WOT, it jumps up only, not down. except i was not messing around with anything in the engine, it just started happening one day. i would like to know the answer to this too.
AMChev
Nov 1, 2005 05:49 AM
type Gendy
Nov 12, 2004 04:38 PM
sit220
Jun 13, 2004 04:07 PM
WhiteEG6
May 25, 2004 09:51 AM
WhiteEG6
May 20, 2004 03:57 AM
