skunk2 manifold throttle response problem. help please!
Old Nov 4, 2008 | 11:12 AM
sean2000gt's Avatar
Default skunk2 manifold throttle response problem. help please!
i just got done installin the manifold and i'm pretty sure everything was right but i guess not. the first 1/4 throttle is fine but afterwards the gas just shuts off. i can hear the intake still sucking but just the gas stops. any idea's? thanks a lot.
Old Nov 4, 2008 | 12:23 PM
sean2000gt's Avatar
i disconnected the sensor on top of the throttle body and the gas worked fine. but the check engine light came on and no vtec. please someone help.
Old Nov 4, 2008 | 12:45 PM
sleepingciv's Avatar
Default Re: (sean2000gt)
sounds like a vac leak some where. do you have all the lines attached?
Old Nov 4, 2008 | 12:57 PM
SoTexDC2's Avatar
Check the TPS and MAP sensor, they're probably reversed.
Old Nov 4, 2008 | 03:01 PM
sean2000gt's Avatar
i checked a picture of before and the tps and map sensor were backwards...but imediately after switching those i noticed that two of the fuel injectors were leaking. so now im stuck finding a o ring kit and firing it back up to test drive it.
One other thing though, i got a p73 (type r) ecu and it's not working. if an ecu is bad, does it not do anything period? cause mine turns over, it just doesn't fire. any ideas? thanks much.
Old Nov 4, 2008 | 03:15 PM
what code is it throwing?
It should throw a code even if the ecu is bad
Old Nov 4, 2008 | 03:43 PM
SoTexDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sean2000gt &raquo;</TD></TR><TR><TD CLASS="quote">i checked a picture of before and the tps and map sensor were backwards...but imediately after switching those i noticed that two of the fuel injectors were leaking. so now im stuck finding a o ring kit and firing it back up to test drive it.
One other thing though, i got a p73 (type r) ecu and it's not working. if an ecu is bad, does it not do anything period? cause mine turns over, it just doesn't fire. any ideas? thanks much. </TD></TR></TABLE>
I'm sure those reversed plugs were part of your problem, i've done the same thing in the past. Get your injector's sorted out and try again.
Each case of a bad ECU is different, does the car run fine with the OEM ecu, and not at all with the ITR ECU?
If your engine is not built with OEM ITR parts, I would not run that ECU. You need something to adjust the vtec engagement at least, just get a socketed P28 and have somebody tune it on crome.
Old Nov 4, 2008 | 04:20 PM
sean2000gt's Avatar
the car will not start with the p73. i've talked to a few people who had gsr's who did the manifold and put a p73 in it and they said it totally woke up the car. but i'm scared i bought a scam. there's no real way to screw up pluggin in an ecu. lol
Old Nov 5, 2008 | 12:28 AM
racebum's Avatar
Default Re: skunk2 manifold throttle response problem. help please! (w3aselll)
i have a p73 and it works great. my engine is extremely similar to an ITR though. crower 401 cams 10:8-1 compression and a blox manifold. have you checked your TPS sensor and verified voltage is correct and also have you double checked ignition timing?
Old Nov 5, 2008 | 03:10 AM
JRSC01GS-R's Avatar
Default Re: skunk2 manifold throttle response problem. help please! (idrivesideways)
what year is the ecu u bought, does it have the immobilizer built into it?
Old Nov 5, 2008 | 11:36 AM
sean2000gt's Avatar
2000 usdm ecu. i read that the older ecu's didn't have the immobilizer.
Old Nov 5, 2008 | 11:45 AM
SoTexDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sean2000gt &raquo;</TD></TR><TR><TD CLASS="quote">2000 usdm ecu. i read that the older ecu's didn't have the immobilizer. </TD></TR></TABLE>
Thats your problem..
00-01 have the immobilizer. You will need to have it removed, or find an older ECU. Search here on HT, there are ways around it.
Old Nov 5, 2008 | 12:51 PM
JRSC01GS-R's Avatar
Default Re: (SoTexDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoTexDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
00-01 have the immobilizer. You will need to have it removed, or find an older ECU. Search here on HT, there are ways around it.</TD></TR></TABLE>
x2
Old Nov 5, 2008 | 06:42 PM
sean2000gt's Avatar
i searchd on how to remove it and it's 3 page articles talking about stealing type r's. saying why should they say how to remove it cause it's prolly stolen blah blah. or someone saying pay 100 bucks and i'll tell ya how. i bought it off ebay, i'll admit. haha. but i guess i'm just going to sell it and buy either an older one or a p28. it'll be a few days until i get the injector gasket kit so i will let everyone know how it works out. thanks for the help guys!
Old Nov 7, 2008 | 05:28 PM
sean2000gt's Avatar
Woo Hoo! got some o rings from lowes and got the injectors back in and the car runs magnificently. it was the MAP and the TPS sensors that were backwards. . thanks for the help guys! now for a chipped p28.. lol
Drzhope89
Apr 25, 2018 07:35 PM
LunarEclipse
Nov 4, 2011 12:43 AM
98CivB18C
21
Aug 29, 2009 05:11 PM
Devious951
Jun 5, 2009 08:25 AM
crashsvg
Oct 27, 2008 02:57 PM
