cleaning fogged up headlights
i no how to clean the fogged lights but my question is this..how u take off the cover so u can clean the inside of the headlight
Modified by em1_fox at 9:05 PM 11/3/2008
put them in the oven at 350 for about 1 minute. Then you can pry them off carefully, clean it, and heat the sealant up again and press them back together.
I've never seen damage on the inside of the lens. It's always on the outside. Clean the outside very well first before you decide to open the light.
There is nothing to have damaged the inside of the lenses.
you actually have to wet sand your headlights with like 800 grit sandpaper then move to 1000 then to 2000. then you will have to buff them out and wax them. that should do the trick....thats how the locals do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_fox »</TD></TR><TR><TD CLASS="quote">i tried cleaning the outside..but nothing happend..it was stilled fogged up..y is it bad to take off the lens</TD></TR></TABLE>
You probably didn't clean them well enough.
What did you clean them with?
I've seen people remove the lenses and clean the inside just to damage them so badly that they need new headlights.
I would not clean the inside of the lens.
i seen people clean headlights with off bug repellent it does work just dont get it on your paint or leave it on too long . Plastic headlights oxidize like no other thats why i have an EJ1 lol
blk2mid2sol
Apr 7, 2008 09:47 AM
