help!!!! no heat
Old Nov 3, 2008 | 01:12 PM
toolow69's Avatar
Default help!!!! no heat
ok, so it almost winter and my heat went out. well not my heat but everything. i checked the underdash fuse and it was good. i pulled the blower motor out and put power to it , it works. i changed out the resistor pack still nothing. nothing will turn on. any clue? help me out im cold!!!
Old Nov 3, 2008 | 02:17 PM
EJcoupeGSR's Avatar
Default Re: help!!!! no heat (toolow69)
check your coolant...if you are low on coolant your heat wont work...do you have a coolant leak or maybe a leaky head gasket?
Old Nov 3, 2008 | 02:24 PM
teamvirus's Avatar
My car breaks a lot!
Default Re: help!!!! no heat (EJcoupeGSR)
thermostat switch, i have the same problem on my car..im to lazy to go fix it but im 99% sure its the switch
Old Nov 3, 2008 | 02:29 PM
mekoz's Avatar
check your climate control. I'm going thru the exact same problem, changed the resistor,fuse and checked the blower motor and relay, but I'm pretty sure my climate control is loose or broken, it works once in a blue moon when I pound on my dash! just kinda figured it out today hah. good luck
Old Nov 3, 2008 | 02:49 PM
toolow69's Avatar
thanks, its not that i dont have heat. it does not blow anything out, thats why i thought it was the blower motor. and my climate control lights went out. still have to check the relay. help!!!!
Old Nov 3, 2008 | 03:17 PM
wrenchez81's Avatar
Default Re: (toolow69)
check the blower motor switch for power and ground............
Old Nov 3, 2008 | 03:23 PM
toolow69's Avatar
Default Re: (wrenchez81)
were is the blower motor switch?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrenchez81 &raquo;</TD></TR><TR><TD CLASS="quote">check the blower motor switch for power and ground............</TD></TR></TABLE>
Old Nov 3, 2008 | 03:33 PM
JDM kitty's Avatar
yea in my daily it is doin the same thing, doesn't blow out anything. sucks, i have to layer up to go anywhere, but hopefully can have it figured out this weekend. fingers crossed
Old Nov 3, 2008 | 03:47 PM
wrenchez81's Avatar
Default Re: (JDM kitty)
the switch that says............... off 1-2-3-4
Old Nov 3, 2008 | 04:04 PM
SOHC_civic_si's Avatar
UGH it's your thermostat. It doesn't work properly. Almost always when a thermostat fails, it fails open, meaning it always stays open, meaning as soon as you start the car your coolant is automatically flowing through your motor, thus not allowing it to heat up, which gives you heat! Just my 2 cents..
Old Nov 3, 2008 | 07:20 PM
srmofo's Avatar
Default Re: (SOHC_civic_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_civic_si &raquo;</TD></TR><TR><TD CLASS="quote">UGH it's your thermostat. It doesn't work properly. Almost always when a thermostat fails, it fails open, meaning it always stays open, meaning as soon as you start the car your coolant is automatically flowing through your motor, thus not allowing it to heat up, which gives you heat! Just my 2 cents..</TD></TR></TABLE>read the post ....there is NO AIR BLOWING THROUGH THE VENTS
if you put power to the blower and it works the problem lies somewhere in between the battery, switch, relay or wiring
Old Nov 3, 2008 | 08:00 PM
jasony0630's Avatar
76.26.106.124
If you have no heat, you're obviously not hitting VTAK...
It's so logical.
You fail
Old Nov 3, 2008 | 09:39 PM
lpc805EG's Avatar
my switch went out a while back... melted the in side of the switch... went to honda delership got a new i think it was like 15 bucks?
dose your switch move to every number and stop? or dose it go from off to 1 2 3 4 with no bump/stop?
civicej897
12
Apr 4, 2013 08:23 PM
Bangher4$
Honda Civic (2001 - 2005)
11
May 22, 2009 01:25 PM
818wHtEG6
Jan 12, 2007 01:44 AM
chuniepatuni
Jan 3, 2007 07:16 PM
808style
Jul 24, 2003 02:50 PM
