car starts REALLY hard, help
Old Nov 3, 2008 | 12:25 PM
didder's Avatar
Default car starts REALLY hard, help
my cars been starting extremely hard, its horribly embarrasing. its a fully built top and bottom end d16 boosted.
i have to hold my foot to the floor or it wont pop at all, once it does fire up i have to keep my foot to the floor for sometimes up to 2 minutes, during this time it will just chug like its only firing on 2 cylinders or something and will not go past 800rpm, then eventually it fires RIGHT up and drives completely perfect.
checked the plugs, there fine, not overly saturated at all, the car just randomly started doing it and i dont understand why.
has anyone had this issue before?
thanks for the help in advance
-didder
Old Nov 3, 2008 | 12:29 PM
93egSLEEPER's Avatar
Default Re: car starts REALLY hard, help (didder)
hows the cap and rotor look?
Old Nov 3, 2008 | 12:57 PM
didder's Avatar
Default Re: car starts REALLY hard, help (93egSLEEPER)
new lol, there ebay but they are brand new
Old Nov 3, 2008 | 02:45 PM
didder's Avatar
bump, any help?
Old Nov 3, 2008 | 03:44 PM
projecthatch92's Avatar
does it do this during all types of weather? what kind of engine management you have
Old Nov 3, 2008 | 04:11 PM
luvmihatch's Avatar
Default Re: (projecthatch92)
i had this problem with my built and boosted d series in a delsol and it started when the weather started to get cold... as soon as the car was warm it went away i got the car retuned and the issue hasnt been since, not saying its the problem but it might be.. gl.
Old Nov 3, 2008 | 04:14 PM
SOHC_civic_si's Avatar
This could be alot of things. Your def misfiring for sure when it's cold, like my motor used to do. All I had to do was seafoam it, get a new battery, adjust the valves and change the oil and it ran perfectly fine. But in your case with having to hold down the gas, sounds like it could be an injector issue. Check their flow and all. Plus the seafoam would really help since it cleans out your injectors, etc. Also could be a plugged fuel filter, bad gas, wrong firing order, lots of things. Gotta start trouble shooting
Old Nov 3, 2008 | 04:24 PM
sounds like its a tuning issue to me. you need to tune it for a cold start.
Old Nov 3, 2008 | 07:08 PM
didder's Avatar
tuned on s300, and it does it even if the motor is still a little warm, but not as bad...
fuel filter is new
lifters were adjusted correctly last week actually
battery is in working condition
car was tuned using s300
ill try sea foaming the biatch, i think its the injectors as well, 3 are fine and the number 1 is wet, so idk wtf that means lol..
honduhh
May 5, 2016 07:13 AM
HaTa
Mar 27, 2006 03:22 PM
greasemonky50
Mar 20, 2006 05:25 AM
