NEE HEPL CHANGING WATER PUMP
Old Nov 3, 2008 | 07:07 AM
tntctr's Avatar
Default NEE HEPL CHANGING WATER PUMP
How do you break the harmonic balancer bolt lose?
Old Nov 3, 2008 | 07:41 AM
HitF8's Avatar
Default Re: NEE HEPL CHANGING WATER PUMP (tntctr)
honda makes a special tool to hold the balancer while you break the nut loose. i will see if i can find a part number for you.
what kind of car/motor is it?
Old Nov 3, 2008 | 07:47 AM
z6hatchboy's Avatar
Well, its going to be hard anyway you do it. You can do it without the tool, just find a way to make the crank/engine stay still (hold the flywheel with something long through the starter hole), then either use a impact (i had to use a 3/4 impact gun) or have a lot of friends help you with a breaker bar. Some guy on here went to his local tire place and got them to break it loose for him and he tightened some there and drove it home and took it off
Old Nov 4, 2008 | 12:35 AM
tntctr's Avatar
Default Re: (z6hatchboy)
1994 HONDA CIVIC DX
Old Nov 4, 2008 | 12:47 AM
tntctr's Avatar
Is it standard or reverse thread?
Old Nov 4, 2008 | 05:42 AM
94EG8's Avatar
Seagull Management
Default Re: (tntctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tntctr &raquo;</TD></TR><TR><TD CLASS="quote">Is it standard or reverse thread?</TD></TR></TABLE>
Plain old right hand thread.
Safebet
Nov 25, 2010 10:33 AM
93EJ1gsr
Nov 1, 2006 10:11 PM
trooper0641
10
Oct 28, 2005 06:04 PM
Charlie Moua
10
Jun 21, 2004 04:13 PM
hitekper4mance
Jan 18, 2004 03:39 PM
