gassy oil
usually thats a sign of the rings, or leaky injectors possibly. But what happens is: one way or another gas or comusted gas in the form of excessive blow by makes its way to the oil cause the rings are wore too much
the head gasket separates the oil passages, coolant passages, and combustion chambers. your oil passage is leaking into your combustion chamber and the gas and oil are mixing together. have you noticed blue smoke out your tail pipe?
Not sure if most of you noticed this or not, but the oil smelling slightly of gas after a few thousand miles would be considered normal. No engine has perfect sealing capabilities, so obviously you're going to have slight blow-by passed the piston rings, meaning the oil will eventually have a fuel smell to it. This is also the reason we have PCV valves.
Also, depending on how many miles are on the motor, how well the motor has been taken care of, etc. could also determine things. Some engines usually just have this problem, such as a a rotary engine. Didn't matter if they were freshly rebuilt or had 100k miles on them, you'd always get fuel dilution in the oil. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Honda_Guy »</TD></TR><TR><TD CLASS="quote">Not sure if most of you noticed this or not, but the oil smelling slightly of gas after a few thousand miles would be considered normal. No engine has perfect sealing capabilities, so obviously you're going to have slight blow-by passed the piston rings, meaning the oil will eventually have a fuel smell to it. This is also the reason we have PCV valves.
Also, depending on how many miles are on the motor, how well the motor has been taken care of, etc. could also determine things. Some engines usually just have this problem, such as a a rotary engine. Didn't matter if they were freshly rebuilt or had 100k miles on them, you'd always get fuel dilution in the oil. lol</TD></TR></TABLE>
Yes all cars do have some blow by, but it is so little that it makes the sealing of the bottom end so good that, that is the reason we have pcv's not so they can vent the blow by, there just not that much blow by. Even with the small amount of blow by present from the factory its not enough to really notice a gas smell from oil. When you get that smell noticably you have a problem.
Also, depending on how many miles are on the motor, how well the motor has been taken care of, etc. could also determine things. Some engines usually just have this problem, such as a a rotary engine. Didn't matter if they were freshly rebuilt or had 100k miles on them, you'd always get fuel dilution in the oil. lol</TD></TR></TABLE>Yes all cars do have some blow by, but it is so little that it makes the sealing of the bottom end so good that, that is the reason we have pcv's not so they can vent the blow by, there just not that much blow by. Even with the small amount of blow by present from the factory its not enough to really notice a gas smell from oil. When you get that smell noticably you have a problem.
If that was the case then why would every vehicle that gets an oil change at 3,000 miles have a slight hint of fuel smell to it? Obviously with the slight bit of blow-by over 3,000 miles you're going to get the slight fuel smell. If you'd like to figure out how many power cycles are in those 3,000 miles be my guest, but during each of those you're getting a slight bit of blow-by. I believe what you're trying to say is if the oil smells strongly of gas after only 500 miles or so, that would indicate more of a problem than if it only smelled slightly of it after a 3,000 mile oil change.
Cleft_Asunder
10
Aug 21, 2008 03:29 PM
