s300 datalogging
Old Nov 2, 2008 | 05:18 PM
SPOOLINmatt's Avatar
Default s300 datalogging
I cant get s300 onboard datalogging to work right even with it wired to the AC pin. Anyone know what the deal is with that. Any thing i can do or just suck it up and give up on it .
Old Nov 3, 2008 | 10:29 AM
havok hybrid's Avatar
Default Re: s300 datalogging (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">I cant get s300 onboard datalogging to work right even with it wired to the AC pin. Anyone know what the deal is with that. Any thing i can do or just suck it up and give up on it .</TD></TR></TABLE>
Do you have you ECU around your ignition box.. (msd)
If so move the msd.
Comfirm you have the dataloger setup correct in Smanger.. Parameters.
Old Nov 3, 2008 | 01:54 PM
Default Re: s300 datalogging (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">
If so move the msd.
Comfirm you have the dataloger setup correct in Smanger.. Parameters. </TD></TR></TABLE>
ya know, i do have it next to msd.
BUT. when i first got my s300 it datalogged every gear with the auto parameters everytime. Then i did a new build and all of the sudden it would only data log 3 and 4 with the auto parameters. The other night when i set it up with a switch, it datalogged no problem every pull i made. Now it won't even activate but maybe at very random times. I have a noise filter on my MSD. Is there maybe something i could put around the ECU to block the interference signal or something?
Old Nov 3, 2008 | 02:09 PM
BUT. when i first got my s300 it datalogged every gear with the auto parameters everytime. Then i did a new build and all of the sudden it would only data log 3 and 4 with the auto parameters. The other night when i set it up with a switch, it datalogged no problem every pull i made. Now it won't even activate but maybe at very random times. I have a noise filter on my MSD. Is there maybe something i could put around the ECU to block the interference signal or something?</TD></TR></TABLE>
I had the exact same issue on one of my cars.. I moved the msd.
You should be able to shield the ecu.. I dont know with what.. lol..
You also might want to look at hondata forum.. maybe its a know issue..
I would guess it has to do with grounds too.
CW96
Sep 9, 2007 06:37 AM
cx-k
Mid-Atlantic (Sales)
21
Jun 12, 2007 11:17 AM
D-meet07
Apr 19, 2006 03:39 PM
DaveF
Northeast (Sales)
Jan 22, 2006 06:52 AM
g2turbo
Aug 30, 2003 10:35 AM
