P0505 code, Car idles high until i block off the IAC???
Old Nov 2, 2008 | 08:22 AM
str8JDMteggy's Avatar
Default P0505 code, Car idles high until i block off the IAC???
This is on a 99 civic lx. I got a CEL and it was P0505 which is an Idle Control Malfunction. The car ides at like 2000rpm when its warm. So i pulled the intake off and started unpluging sensors too see if it made a difference. I found that if i put my finger over the hole in the throttle body that goes to the IAC is idles perfect. So i swaped in another IAC and it does the same exact thing. Any ideas?
Old Nov 2, 2008 | 08:26 AM
T3KNiQe's Avatar
Default Re: P0505 code, Car idles high until i block off the IAC??? (str8JDMteggy)
Play around with the FITV clean it out and see what happens
Old Nov 2, 2008 | 08:35 AM
Thought 96 and newer cars dont have a FITV
Old Nov 2, 2008 | 08:50 AM
wrenchez81's Avatar
Default Re: (str8JDMteggy)
see if the sas air bypass screw is turned too loose... or try unplugging the tps.......... any vaccum leaks?? throttle stop screw been tampered with?? idle kicker for ac may be signaling iacv to compensate fo calculated ac load...
Old Nov 2, 2008 | 09:04 AM
o vucumm leaks i did unplug the tps and nothning, the throttle screw has not been touched
Old Nov 2, 2008 | 09:08 AM
wrenchez81's Avatar
try turning the by pass screw all the way to the right ........... no offense meant but do you know where this is?? it is not the throttle stop screw..
Old Nov 2, 2008 | 03:25 PM
But the car was running fine before this happened so how would the bypass screw out of spec?
Old Nov 7, 2008 | 02:26 PM
bump
Old Nov 8, 2008 | 07:38 AM
up
s13hero
13
Apr 17, 2017 09:37 AM
phelpsj2
Nov 3, 2011 02:35 PM
dth0ng69
Nov 11, 2009 09:16 AM
fronomo
Aug 28, 2007 03:56 PM
Problemo
Jan 29, 2006 04:16 PM
