hoew do I make a universal slim fan a push?
Old Oct 30, 2008 | 11:16 PM
acmoc's Avatar
Default hoew do I make a universal slim fan a push?
Do I cross the wires, or Do I have to flip the blades. I heard I just cross the polarity
Old Oct 31, 2008 | 03:07 AM
traxxasx's Avatar
Default Re: hoew do I make a universal slim fan a push? (acmoc)
yea switch wires.
Old Oct 31, 2008 | 07:48 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: hoew do I make a universal slim fan a push? (traxxasx)
Switching polarity is required, but every push/pull fan I have installed also says in the instructions to flip the blade if you want to make a pusher a puller and vice versa.
Old Oct 31, 2008 | 12:02 PM
acmoc's Avatar
Default Re: hoew do I make a universal slim fan a push? (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">Switching polarity is required, but every push/pull fan I have installed also says in the instructions to flip the blade if you want to make a pusher a puller and vice versa. </TD></TR></TABLE>
Yea thank you, that's rite. butt really, I want to know if the stock fan is a pull or push
Old Oct 31, 2008 | 12:10 PM
90sedan's Avatar
Stock fan is a pull. If it's mounted on the backside of the radiator it should always be setup as a puller.
Old Oct 31, 2008 | 12:47 PM
acmoc's Avatar
Default Re: hoew do I make a universal slim fan a push? (90sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan &raquo;</TD></TR><TR><TD CLASS="quote">Stock fan is a pull. If it's mounted on the backside of the radiator it should always be setup as a puller. </TD></TR></TABLE>
Thanks guys, problem solved now
killafred187
18
May 27, 2007 08:55 PM
MattsGreenEG
Mar 10, 2007 04:23 PM
mike93eh2
13
Feb 17, 2007 04:23 PM
Mr Synister
Mar 16, 2006 10:41 PM
Smooth-GSR
May 1, 2004 11:53 AM
