replacing clutch and throw-out bearring
Old Oct 30, 2008 | 03:06 PM
supercoy101's Avatar
Default replacing clutch and throw-out bearring
im replacing my clutch, pressure plate, fly wheel and throw out bearring on my 95 honda cx
seeing how this is my first honda it wld be nice if i cld get some help on how to go bout doin this...since i will attempt it myself
ne hints or advice wld be helpful
thanx
Old Oct 30, 2008 | 03:46 PM
ns060's Avatar
Default Re: replacing clutch and throw-out bearring (supercoy101)
you might want to use the search button bro, its not an easy task! i would rate it about a 5/10 if you have any mechanical knowledge.
Old Oct 30, 2008 | 04:25 PM
andoxviii's Avatar
A large portion of this thread may be of use to you:
https://honda-tech.com/zerothread?id=596873
Old Oct 30, 2008 | 05:20 PM
blkegcoupe's Avatar
From: ....................................................................................................
It's fairly easy,
Step 1 Jack up car on Jack Stand's
Step 2 Remove axles from transmission
step 3 Drain Transmission Fluid
Step 4 remove all unecessary ground cables
step 5 move radiator over to get access to slave cylinder and remove that *10 mill bolts.
Step 6 remove rear transmission mounts
Step 7 remove VSS sensor plug on top of transmission and then remove starter *don't forget to unplug battery*
step 8 remove torgue mount
Step 9 move exhaust manifold out of way.
step 10 begin to remove transmission
step 11 after removing transmission use a 10mill 12*point socket to remove clutch plate and housing then so for with the rest and everything else to reinstall is in reverse also a d series transmission requires 2 quarts of motor oil 10 weight or i used shock proof but perferbly also honda transmission manual fluid.
pm me with questions i can walk you throught it.
Old Oct 30, 2008 | 05:41 PM
Default Re: (blkegcoupe)
thanx man sounds easy enough
preciate it
Old Oct 30, 2008 | 05:42 PM
Default Re: replacing clutch and throw-out bearring (ns060)
this aint my first rodeo son
Old Oct 30, 2008 | 05:43 PM
Default Re: (andoxviii)
thanx
Old Oct 30, 2008 | 07:49 PM
daveedo's Avatar
http://hondatech.info/downloads/Auto/Manuals/Civic/
The manual will also help alot too. I just found it
Old Oct 30, 2008 | 08:38 PM
Frickr's Avatar
Default Re: (daveedo)
a trick ive learned if the pilot bearing is stuck (which you should replace with your clutch) is to take and pump a bunch of grease into the hole, then take a dowl rod with some tape or whatever you can find to be a good fit in the hole, then push it in and tap with a hammer. saves alot of time.
steinbacheg6
Dec 28, 2007 05:07 AM
CodyC142
Nov 18, 2006 08:04 AM
Myh4tch
Nov 17, 2003 05:21 AM
See Are X
May 19, 2002 05:21 PM
