OBD1 LS motor into a 2000 Hatch whats all needed
Old Oct 29, 2008 | 12:55 PM
Ep1dem1c's Avatar
Default OBD1 LS motor into a 2000 Hatch whats all needed
Motor: OBD1 LS with Hydro Tranny
Car: 2000 Honda Civic Hatchback
whats all need to make this work properly...
the motor is coming out of a del sol that had this swap
Old Oct 29, 2008 | 05:48 PM
Ep1dem1c's Avatar
Default Re: OBD1 LS motor into a 2000 Hatch whats all needed (Ep1dem1c)
ttt
Old Oct 30, 2008 | 07:21 AM
Ep1dem1c's Avatar
Old Oct 30, 2008 | 07:28 AM
davefromPA's Avatar
List of needs
OBD1 Engine harness that will plug right in no problems
B-series linkage for an eg (the del sol one is different and rare)
Stock mounts from a DC
axles
its a straight-forward swap. if you need help, i live close by and will help for a small fee or parts. just a thought.
also, that shift linkage is worth more then the average linkage because the del sol b-series is much different/ rare then anyother linkage.
pm me if you need my number to help.
Old Oct 30, 2008 | 07:32 AM
davefromPA's Avatar
Default Re: OBD1 LS motor into a 2000 Hatch whats all needed (davefromPA)
wait. wait i just read its for a 2000 civic.
your gonna need a obd2 to obd1 jumper harness for the ecu. (OBD1 LS ecu)
si mounts
the other stuff i said.
Old Oct 30, 2008 | 11:40 AM
Ep1dem1c's Avatar
actually im asking for a friend.... thanks though
thanks a lot for the help
Old Oct 30, 2008 | 02:01 PM
Johnny Is Bored's Avatar
to be honest with you if you want to make your life easier it is always best to use your original harness just get the the plug and play injector clips from passwordjdm.com and change your distributor plug to obd 1. I use to have the exact same setup and following above is needed also. Good luck
Old Oct 31, 2008 | 09:27 AM
Ep1dem1c's Avatar
Default Re: OBD1 LS motor into a 2000 Hatch whats all needed (Johnny Is Bored)
will the cable transmission mount from the del sol work on the EK? (Yes they put the cable tranny in the del sol with a conversion kit)
cody_sandlin
Aug 9, 2013 05:19 AM
monsterb18b
Aug 11, 2008 06:11 AM
PinoyDelSol
Nov 4, 2007 06:31 PM
vtec25
Dec 6, 2006 04:23 AM
93LSTurboSol
Nov 4, 2004 07:53 AM
