OBD1 LS motor into a 2000 Hatch whats all needed
Motor: OBD1 LS with Hydro Tranny
Car: 2000 Honda Civic Hatchback
whats all need to make this work properly...
the motor is coming out of a del sol that had this swap
Re: OBD1 LS motor into a 2000 Hatch whats all needed (Ep1dem1c)
List of needs
OBD1 Engine harness that will plug right in no problems
B-series linkage for an eg (the del sol one is different and rare)
Stock mounts from a DC
axles
its a straight-forward swap. if you need help, i live close by and will help for a small fee or parts. just a thought.
also, that shift linkage is worth more then the average linkage because the del sol b-series is much different/ rare then anyother linkage.
pm me if you need my number to help.
axles
Re: OBD1 LS motor into a 2000 Hatch whats all needed (davefromPA)
wait. wait i just read its for a 2000 civic.
your gonna need a obd2 to obd1 jumper harness for the ecu. (OBD1 LS ecu)
si mounts
the other stuff i said.
si mounts
actually im asking for a friend.... thanks though
thanks a lot for the help
to be honest with you if you want to make your life easier it is always best to use your original harness just get the the plug and play injector clips from passwordjdm.com and change your distributor plug to obd 1. I use to have the exact same setup and following above is needed also. Good luck
Re: OBD1 LS motor into a 2000 Hatch whats all needed (Johnny Is Bored)
will the cable transmission mount from the del sol work on the EK? (Yes they put the cable tranny in the del sol with a conversion kit)
cody_sandlin
08-09-2013 05:19 AM
vtec25
12-06-2006 04:23 AM
