Y7 compression test results
Old Oct 29, 2008 | 11:27 AM
UserX826's Avatar
Default Y7 compression test results
#1 - 125
#2 - 120
#3 - 130
#4 - 100
Ran the test because of white smoke.. possible that #4 has bad rings?
Old Oct 29, 2008 | 11:31 AM
blkegcoupe's Avatar
From: ....................................................................................................
most likely your head gasket is going, those are usually the symptons,
-white smoke
-loss of compression
-coolant loss
-coolant in oil/oil in coolant
if i were you i get to this and make sure its a head gasket before it hurts your motor in the long run.
also a headgasket is not very difficult to do, i'd did one myself and before i've never worked on a honda before *my first ej1* but even though you could do it yourself also, just go to the local parts store and pick up a cheap haynes manual and use that to help you.
also just checking your sig, do you have a Y7 motor in your ex coupe?
Old Oct 29, 2008 | 11:33 AM
90Rexx's Avatar
Default Re: Y7 compression test results (UserX826)
#4 is about 28-30% less than your best cylinder...so your rings are probobly worn out...but thats not terrible...id think its time for a rebuild though your readings across the board are a little low....plus your white smoke is probobly a headgasket....
Old Oct 29, 2008 | 11:35 AM
90Rexx's Avatar
Default Re: Y7 compression test results (90Rexx)
just to clarify, only reason you should re-ring is cuz ur heads gonna be off for the headgasket anyways....
in other news....i have a full gsr swap if your interested....100k miles on it fresh timing belt + tensioner...bone stock. comes with everything u need for the swap.
Old Oct 29, 2008 | 11:41 AM
UserX826's Avatar
Well that's the thing.. This is a fresh rebuild. the Y8 broke a rod in half and put a hole in the block. So i rebuilt a Y7 block, kept the Y8 head on.
New headgasket, new rings.. but it's more likely for the rings to be bad than the headgasket i think b/c the cylinders had a little residue in them.. got rained on after i had the block honed.. got a hone from autozone and went through the cylinders myself
Also, changed my sig. I'm broke!
Old Oct 29, 2008 | 11:44 AM
jimmy o.'s Avatar
check your timing
Old Oct 29, 2008 | 11:49 AM
UserX826's Avatar
timing is gonna cause white smoke?
Old Oct 29, 2008 | 11:50 AM
jimmy o.'s Avatar
well idk but seeing how your comp is low across the board your timing would be a good suspect being this a rebuilt engine you sure it isnt just gray smoke fom unburned fuel
Old Oct 29, 2008 | 11:53 AM
UserX826's Avatar
yeah. it's white from the VC vent
Old Oct 29, 2008 | 11:58 AM
jimmy o.'s Avatar
you got all your little coolant lines hooked up right i saw a 96 ex with a d15b that had a coolant line running into the crankcase it was a mess. did you replace your intake gasket
Old Oct 29, 2008 | 12:00 PM
UserX826's Avatar
lol. wow. yeah it's all hooked up right. didn't replace the intake gasket.. never took the intake off of the head during the swap
trojan
Feb 26, 2012 02:18 PM
avotegra
Dec 13, 2009 11:45 PM
93coupe1330
Nov 1, 2009 10:09 PM
Hulk_EJ8
Jun 5, 2006 12:43 PM
som3on3_10
May 20, 2006 05:49 PM
