Wiring problem HELP!!!!
Old Oct 28, 2008 | 08:04 PM
kambosoup's Avatar
Default Wiring problem HELP!!!!
So I have a 90 civic si. The car had a LS motor in it before. I just got the shell. Now, I have put in a mini me swap. d16a6 block with a z6 head from a del sol. I have a crx si harness that I had put in. The vtec isnt connect yet. I also have the obd1 harness that was with the motor from the delsol. I am using a pm6 ECU. When turing the car on to a.c.c. I heard the fuel spraying, but the car doesnt want to start. If i spray carb choke the car will start, but after it will shut off. Im not really sure what the problem is. Can someone please help me.
Old Oct 28, 2008 | 08:08 PM
D16SiHatch's Avatar
Default Re: Wiring problem HELP!!!! (kambosoup)
are your injectors set up right? be it obd0 injectors with the resistor box, or obd1 without?
Old Oct 28, 2008 | 08:35 PM
kambosoup's Avatar
Default Re: Wiring problem HELP!!!! (D16SiHatch)
Yeah, I had copied the color code from another hatch. I have the resistor box still in
Old Oct 28, 2008 | 10:52 PM
D16SiHatch's Avatar
and you are still using the stock intake with obd0 injectors i presume?
Old Oct 29, 2008 | 05:35 AM
punkdown's Avatar
Are you using OBD0 or OBD1 injectors? Because if you are using OBD1 they don't need the resistor box.
Old Oct 29, 2008 | 09:44 AM
kambosoup's Avatar
Default Re: Wiring problem HELP!!!! (punkdown)
I am using the obd1 injectors. The motor start, when opening the throttle and spraying carb choke. But when I dont spray, it will just die out.
Old Oct 29, 2008 | 09:53 AM
IndySporty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkdown &raquo;</TD></TR><TR><TD CLASS="quote">Are you using OBD0 or OBD1 injectors? Because if you are using OBD1 they don't need the resistor box.</TD></TR></TABLE>X2, you need some obd-0 injectors, or you need to cut the wires off the resistor box and splice them all together. If unsure, then get yourself a multimeter and check the injectors (positive to one side of the injector, negative to the other) and they should give you about 2-3 ohms of resistance. If they are giving about 10-14 then you cant run the resistor box, the ECU will not fire them.
Old Oct 29, 2008 | 11:05 AM
kambosoup's Avatar
Default Re: Wiring problem HELP!!!! (IndySporty)
would it just be easier to use the obd1 injectors and cut out the resistor box?
bigodub93
Jan 11, 2008 05:30 PM
EK FLY
Jul 25, 2006 09:55 AM
brnyrdcmndo
Aug 9, 2005 09:24 PM
mr. Grind
Aug 15, 2004 12:13 PM
KevronsEG
Nov 7, 2002 09:25 AM
