Mysterious water leak :[
I have a 90 civic si and I noticed that water gets in somehow from the hatch I think. There was water where the spare tire should be. Now nothing else in the car is wet. I checked the weather stripping and it all seems legit. Im stumped here. Any idea what I could check for?
i just had to put silicone on my tail light gaskets i waited for it to rain pretty good out and took the plastics off and i seen it leaking pretty good threw there.
get a friend and a garden hose, remove the back plastics that cover the tails youll see it leaking there
have a friend run water on it you get in there car
sunroof drain tube is clogged
weather stripping
bad taillight gaskets
rear washer fluid nozzle
area where hatch meets needs sealant
window gaskets
https://honda-tech.com/zerothread?id=1958029
https://honda-tech.com/zerothread?id=2164437
https://honda-tech.com/zerothread?id=2289120
Modified by gringo7718 at 12:04 AM 10/29/2008
weather stripping
window gaskets
raverx3m
Nov 25, 2013 04:49 AM
