Honda S2000 Honda S2000
Car keeps shutting off!
Old Oct 27, 2008 | 03:05 PM
d_EG COUPE's Avatar
Default Car keeps shutting off!
well its weird. like if u cruise the car it wont turn off and everything is normal. but the second u smash, lets say on the freeway and hop off the freeway to a light or stop sign the cars wants to or even some times turn off. then it does that the rest of the day. every time you come to a stop sign or sumthin it just turns off or gets to the point where it wants to but doesnt. but when i smash at night everythings perfectly fine. So I'm thinkin it has to do something with the temp. but idont knoe. this has never happen in my hatch or nothing, so this is new to me.
Old Oct 27, 2008 | 03:46 PM
d_EG COUPE's Avatar
Default Re: Car keeps shutting off! (d_EG COUPE)
Old Oct 27, 2008 | 04:42 PM
bigmacnfries's Avatar
stop smashing - and go get your sensors checked..
Default Re: Car keeps shutting off! (bigmacnfries)
map sensor
Old Oct 27, 2008 | 05:28 PM
d_EG COUPE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigmacnfries &raquo;</TD></TR><TR><TD CLASS="quote">map sensor</TD></TR></TABLE>
but theres no check engine light
Old Oct 27, 2008 | 05:48 PM
d_EG COUPE's Avatar
and when i changed the spark plugs today the ignition coils were all moist and brown
Old Oct 27, 2008 | 08:17 PM
d_EG COUPE's Avatar
any1 else
Old Oct 27, 2008 | 08:28 PM
jefferyg32's Avatar
Default Re: (d_EG COUPE)
You have lost compression in 1 or more of the cylinders. Do a compression check and it will tell you exactly why the car keeps shutting off.
Old Oct 27, 2008 | 08:30 PM
SLVRSTN_DC4's Avatar
did you check your vaccum lines? i haven't had that problem with my s2000 at all, but I would always check the condition of the lines. sorry i couldn't be more helpful.
Old Oct 27, 2008 | 09:08 PM
d_EG COUPE's Avatar
Default Re: (SLVRSTN_DC4)
thank u any one else
Old Oct 28, 2008 | 05:54 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (jefferyg32)
I don't think it's your compression. What does your car idle at when warm. Sounds like you could have a small vacuum leak, your IACV needs to be cleaned, or your idle is set to low (can be adjusted VIA screw). I would also give it a good sea foam treatment.
Old Oct 28, 2008 | 11:24 AM
d_EG COUPE's Avatar
Default Re: (White Smoke)
it never did this b4 to be idle havin to be to low. its always idles at like 1. but now dont even want to stay at 1.
Old Oct 28, 2008 | 11:45 AM
joey1320's Avatar
what exactly have you done to the car??? any mods or recent maintenance?
Old Oct 28, 2008 | 12:06 PM
d_EG COUPE's Avatar
Default Re: (joey1320)
no mods. just did oil change and changed spark plugs. but i changed them after the problems happned
Old Oct 28, 2008 | 12:20 PM
ReddotsS2K's Avatar
is anything else happening? (any weird sounds, flickering lights, etc)
Old Oct 28, 2008 | 12:29 PM
i my honda
Global Mod
OK, don't listen to anything anyone suggests then and figure it out on your own
Old Oct 28, 2008 | 01:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">OK, don't listen to anything anyone suggests then and figure it out on your own </TD></TR></TABLE>
Thats what I thought, just because everything is ok at one point and then something happens is usually the process when something goes bad, it's unexpected, it happens to all of us. Just like I said and White Smoke, check for vacuum leaks.
The IACV sounds right, just like White Smoke said, was just thinking that Plus, I would clean the throttle body just for kicks too, just in case there are any clogged ports.
Old Oct 28, 2008 | 08:29 PM
megalomaniac001's Avatar
i was actually on my way to post saying I had the same problem when I found this thread. Mine is shutting off whenever I come to an idle at a stop sign or light or whatever. Also, it feels like I have a misfire around 4-5k RPM. Pulled my codes (I constantly have one for my test pipe) and along with the rear o2 I was saying low voltage out of the TPS. So between the MAP and the TPS I wouldn't rule out anything yet. Both sensors can be checked indiviually so I would just whip the OHM meter back out, get some specs on what the resistances (or voltages) should be and start checking sensors. Happy Hunting!
Old Oct 29, 2008 | 08:43 PM
d_EG COUPE's Avatar
i was just askin its not like i was doin this i was just tryin to get every1's opinion. But i figured it out thanx to u guys. i changed one of my ignition coils that i thought was F***ed up and cleaned the throttle body! and now its runnin strong thanx guys!!!
Old Oct 30, 2008 | 04:58 AM
i my honda
Global Mod
Old Oct 30, 2008 | 03:49 PM
Old Oct 31, 2008 | 04:17 AM
F22Bankai's Avatar
Default Re: (megalomaniac001)
To megalomaniac001
Do you have an anti fouler fix for your test pipe? Little piece that extends your O2 sensor on your test pipe. That should clear your CEL. If you got a shitty idle, try cleaning out your throttle body. Most of the time its just dirty and needs a clean. Good luck
Show15
Engine Management and Tuning
Oct 14, 2015 10:43 PM
kenfu
Sep 16, 2008 04:15 PM
EJ1 Type Slow
Jul 28, 2007 12:24 PM
Stevegunit16
10
Feb 14, 2007 07:21 PM
sloaccrd
Jun 21, 2005 09:46 PM
