What tranny to get for a 1999 ls?
Old Oct 27, 2008 | 01:04 AM
longstuhh's Avatar
New User
Default What tranny to get for a 1999 ls?
im needing a new tranny and i was wondering if i should just go with another stock one or with a upgrade im not needing lsd so i dont wanna get to into fixing it up
Old Oct 27, 2008 | 01:49 AM
Jimmy's Avatar
Global Moderator
You plan on boosting? Staying all motor? Tracking the car?? what are your goals/intentions to do with the car and we can go from there
Old Oct 27, 2008 | 09:52 AM
AWD Terror's Avatar
Default Re: (Jimmy)
As stated above, it all depends on your plans for the car.
If you want it to just be a nice DD, keep the stock tranny.
Old Oct 27, 2008 | 09:14 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (AWD Terror)
ls if ur boosting or DD.
gsr or itr for everything else.
Old Oct 27, 2008 | 09:49 PM
Spec R's Avatar
Default Re: (00IntegrAllmotoR)
since you said you dont "need an LSD", i'm assuming you wont be doing any high performance driving, which is perfectly fine.
given these days gas prices, just get another LS.
B16/ITR are too short leaving freeway cruising RPMs a bit too high than what would be optimal for the LS powertrain.
GSR is a nice compromise.
Old Oct 27, 2008 | 11:07 PM
TOO MUCH TORQUE's Avatar
the gsr's semi short gears would really compliment the ls's low end torque. And put in a ls 5th gear. that would be my ideal tranny for an b18b1
Old Oct 28, 2008 | 07:33 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (TOO MUCH TORQUE)
The GSR trans sucks so much, though. The gear deltas are too big. I didn't like mine. I had a DD GSR. I now have a DD EM1.
The GSR would have been so much more fun with a B16A trans. I almost traded someone, but it fell through.
The B16 trans really isn't as bad as people say on the freeway. I drive between 80-100 miles a day, 5 days a week, and about 50-75% of that is freeway driving with my EM1. I set the cruise at 70-75, and go to sleep or make myself a sandwich (because that's what you do with Cruise control on). It sits around 4k...no biggie...I still get 30-31MPG including the around town driving.
You may not want your LS sitting at 4k on the highway since it's a longer stroke motor...but it would be really fun around town seeing as the LS makes good torque. Since you wouldn't be lugging the engine due to the shorter gears, you'd probably save gas around town too.
So try either the GSR or B16/ITR trans...I wouldn't just replace with an LS. I'd prefer the B16 trans.
Look at the gas mileage numbers for integras on edmunds.com.
The GSR and LS are both 25/31, IIRC.
The ITR is 25/30.
The ITR has a 1.8L and is geared like the B16A. So according to EPA recorded numbers, you probably stand to lose around 1mpg by switching to a B16 trans.
Obviously, this totally depends on how fast you go on the highway. The faster you go, the faster the mileage will drop off. It's not quite a linear relationship as far as that goes.
I can say that at around 70-75mph freeway driving and around town driving, there was about a 1mpg difference between my GSR and EM1.
Old Oct 28, 2008 | 08:06 AM
omnirage's Avatar
Default Re: What tranny to get for a 1999 ls? (longstuhh)
Search, search, search.
GSR tranny for a stock powerband/redline LS.
p1ccoloz
May 6, 2003 01:02 AM
Turbo_Teg
Nov 14, 2002 09:37 PM
KamikazeRacinz
Apr 18, 2002 12:54 PM
intevic2010
Aug 28, 2001 10:04 AM
