Any way to tell if a motor is good/bad off the car?
Old Oct 23, 2008 | 09:38 PM
SiYouLater's Avatar
Default Any way to tell if a motor is good/bad off the car?
So I will be purchasing a longblock sometime soon and I was wondering what to look for to tell if the motor is bad or not. I know that I can do a leakdown test, but what else?
Old Oct 23, 2008 | 10:00 PM
iamthefollower's Avatar
Default Re: Any way to tell if a motor is good/bad off the car? (SiYouLater)
Check for metal shavings in the oil..
Is the motor out of the car??
Old Oct 23, 2008 | 10:24 PM
SiYouLater's Avatar
Default Re: Any way to tell if a motor is good/bad off the car? (iamthefollower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower &raquo;</TD></TR><TR><TD CLASS="quote">Check for metal shavings in the oil..
Is the motor out of the car??</TD></TR></TABLE>
Yup.
Old Oct 23, 2008 | 10:27 PM
also take the valve cover off and see how good the inside of the head looks, if it is corroded with oil then more than likely it is going to smoke.. other than that I would just make sure it had all of it's sensors, since you already know bout the leak down test.
tianporn
Nov 3, 2005 03:28 PM
toEknEEg
Jul 17, 2005 01:30 PM
kihun_cha
13
Oct 6, 2004 11:49 AM
BOOSTIN1
Apr 26, 2004 06:52 PM
B18C1 '96 Coupe
14
Jan 2, 2003 02:00 PM
