b16a swap HELP
i have a 2000 civic hx and im puting a obd1 b16a, i have hasport mounts skunk2 jumper all the main stuff, what should i do 4 a harness i also have the complete hx harness and i have a p30 ecu, im in spokane and i need to drive back to south dakota in 2days please help.
easy.. you have the distributor conversion jumpers? do you have the conversion jumpers for the fuel injectors? the obd1 is 1 wire while the obd2 is 2 wires.. I believe the only thing you have to worry about is the o2 sensor plugs.. in an hx is it 5? I forget but you need a 4 pin plug for the o2 wire.. so you might have to find a conversion jumper for that too or manually wire it yourself.. other than that your set..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonfedjdm »</TD></TR><TR><TD CLASS="quote">i dont have the jumper 4 the dizzy and hx is 5wire o2</TD></TR></TABLE>
you need the jumper from a 1 peice wire to a 2 peice for your hx harness to work.. I dont know if they sell those though.. they usually sell from obd2a/b distributor wire ==> obd1 harness.. and you also need to convert your 5 wire o2 sensor to a 4 wire.. oh man the hx is alot of work.. I believe the back bracket moutn is also welded on the chasis of the car therefore your gonna have to do some cutting and welding!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raidacaipo »</TD></TR><TR><TD CLASS="quote">reallly??? what motor was in the hx before? usually the stock ones have the rear engine bracket mounts welded onto the chasis of the vehicle like my friends hx.. </TD></TR></TABLE>
Was your friend's HX by any chance a CVT? Those are supposed to have some wierd mounting points or something.
no just a hx i had no problems bolting the mounts in everything works now, im just waiting 4 the obd2b to obd1 jumper it should be here 2nite cuz my buddy ordered the wrong 1 but we got the car fired up last night useing the stock hx ecu, i got all the wire harness built with no problems i just serched google 4 a lil while and found all that i needed. thanks guys.
happyabortion
Jun 25, 2006 08:25 AM
blackeg
Sep 29, 2004 02:49 PM
