no vtec no codes
so i changed my clutch and axles, now vtec isnt working.
checked all wiring. tested the solenoid with an ohmmeter, ok, ran a wire to the positive batt term, clicked. checked the screen, clean.
vss connected, plugged in. speedo works
oil level is to the top dot.
vtec worked fine the day i started working on it.
any input appreciated, ive never had a problem like this and all my friends and i are stumped.
the one time i had that prob i changed the oil n put in some new one..apparently the oil i had in it did its time and began to thin out which cased my v-tech not to chip in ..its a long shot but u cud try it..i notice u said the oil was at the top but is the oil any good??it worked for me any how..i did all the stuff u did check wires and all nun worked.but it worked when i changed the oil..
i changed the oil maybe a week before the clutch went, i used a mobil 1 filter, which i never used before. i know vtec worked bc i engaged it as the clutch started slipping, so it worked fine.
however, you're not the only one to suggest that so ill try changing it when i get home this afternoon. i doubt it will work but thanks.
anyone else?
anyone else?
as of this evening i changed the oil/filter and plugs. still nothing. i let the car warm up pretty well too, fans were coming on. still no codes. this really sucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 »</TD></TR><TR><TD CLASS="quote">did someone before you have the car and disconnected the engine light in the cluster? either that or you ECU isn't workin right</TD></TR></TABLE>
no, i recently had code 7. replaced the tps. as of this morning, anything i disconnect under the hood i do not get a code for? im trying to find someone in my area with an obd1/2 vtec ecu.
