no vtec no codes
Old Oct 23, 2008 | 05:27 PM
HONDRETTI's Avatar
Default no vtec no codes
so i changed my clutch and axles, now vtec isnt working.
checked all wiring. tested the solenoid with an ohmmeter, ok, ran a wire to the positive batt term, clicked. checked the screen, clean.
vss connected, plugged in. speedo works
oil level is to the top dot.
vtec worked fine the day i started working on it.
any input appreciated, ive never had a problem like this and all my friends and i are stumped.
Old Oct 23, 2008 | 07:49 PM
HONDRETTI's Avatar
Default Re: no vtec no codes (HONDRETTI)
anyone?
Old Oct 23, 2008 | 08:06 PM
crashsvg's Avatar
the one time i had that prob i changed the oil n put in some new one..apparently the oil i had in it did its time and began to thin out which cased my v-tech not to chip in ..its a long shot but u cud try it..i notice u said the oil was at the top but is the oil any good??it worked for me any how..i did all the stuff u did check wires and all nun worked.but it worked when i changed the oil..
Old Oct 24, 2008 | 05:03 AM
HONDRETTI's Avatar
Default Re: no vtec no codes (crashsvg)
i changed the oil maybe a week before the clutch went, i used a mobil 1 filter, which i never used before. i know vtec worked bc i engaged it as the clutch started slipping, so it worked fine.
however, you're not the only one to suggest that so ill try changing it when i get home this afternoon. i doubt it will work but thanks.
anyone else?
Old Oct 24, 2008 | 04:09 PM
HONDRETTI's Avatar
as of this evening i changed the oil/filter and plugs. still nothing. i let the car warm up pretty well too, fans were coming on. still no codes. this really sucks.
Old Oct 24, 2008 | 08:18 PM
4dooritr's Avatar
try another ecu
Old Oct 25, 2008 | 12:00 AM
crxstylin's Avatar
with vtec not working you should get a code, try ridding first gear at 7000rpm for 5 seconds, it should make the light come on then and give you a better idea of whats wrong.
Old Oct 25, 2008 | 07:53 AM
HONDRETTI's Avatar
Default Re: (crxstylin)
if i unplug something under the hood for example my MAP, i should get a code for it, right? i just tried that, and i didnt get a code... wtf?
Old Oct 25, 2008 | 08:08 AM
LSracing94's Avatar
Default Re: (HONDRETTI)
did someone before you have the car and disconnected the engine light in the cluster? either that or you ECU isn't workin right
Old Oct 25, 2008 | 08:16 AM
HONDRETTI's Avatar
Default Re: (LSracing94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">did someone before you have the car and disconnected the engine light in the cluster? either that or you ECU isn't workin right</TD></TR></TABLE>
no, i recently had code 7. replaced the tps. as of this morning, anything i disconnect under the hood i do not get a code for? im trying to find someone in my area with an obd1/2 vtec ecu.
Old Oct 25, 2008 | 09:11 AM
LSracing94's Avatar
some info on the car?
is it swapped, what year, what year motor and so on
Old Oct 25, 2008 | 09:24 AM
HONDRETTI's Avatar
98 integra ls/vtec gsr, p28 chipped with crome, obd2 to 1 conversion
Old Oct 25, 2008 | 09:46 AM
LSracing94's Avatar
yeah man im thinking there is an issue within the ecu
shytdoode
15
May 11, 2010 06:10 PM
FSS13foxtrot
Dec 28, 2007 12:32 AM
jbell
Mar 5, 2006 06:34 PM
da9driver
24
Aug 25, 2005 01:00 PM
01-1293
Oct 9, 2002 03:03 PM
