Transmission dipstick on type s?
Old Oct 23, 2008 | 03:06 PM
RSX_S's Avatar
Default Transmission dipstick on type s?
I have type s and my question is this... Is there any way to check the transmission fluid without taking the car in? Ive had the transmission fluid changed about 6 months ago but now im wondering if maybe im low on fluid for some reason. When i start out in first gear im starting to notice vibration when going into gear. No other gears do it. Could be something else with the transmission or maybe the axles, i have no idea. Any info helps! thanks
Old Oct 23, 2008 | 03:25 PM
eMpAtHy's Avatar
Default Re: Transmission dipstick on type s? (RSX_S)
i think the only way is to remove the fill plug on the tranny and see if you can put more in there.
Old Oct 23, 2008 | 03:47 PM
WhiteOnRice's Avatar
There is no dipstick.
https://honda-tech.com/zero...92340
Old Oct 23, 2008 | 04:08 PM
RSX_S's Avatar
SO0o... does that mean unbolt the plug bolt and just put whatever i can in it? Do you fill it through the plug bolt as illustrated by the red arrow on the writeup mentioned by whiteonrice?
Old Oct 23, 2008 | 04:11 PM
Fill it until the oil starts draining from the hole where the red arrow is on the bottom left. I use clear vacuum hosing from the hardware store and a regular funnel.
The write up was by WyldRice, not me. Damn us ricers!
Old Oct 23, 2008 | 04:37 PM
RSX_S's Avatar
So where do i put the fluid in? The red arrow hole?
Old Oct 23, 2008 | 04:39 PM
Yes with the funnel and hose I mentioned. It's not very quick and easy btw.
Old Oct 23, 2008 | 05:10 PM
RSX_S's Avatar
Doesnt look too hard. Thanks. I doubt this is my problem though =/
Old Oct 23, 2008 | 05:45 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
what fluid are you using? I switched to synchromesh and it made a world of difference. But I also have to change my trans fluid every other oil change cause synchromesh doesn't last very long.
Old Oct 23, 2008 | 06:44 PM
Just use Honda/Acura tranny fluid. And yeah, I doubt this is the problem.
Old Oct 27, 2008 | 03:09 AM
_Simon_'s Avatar
Default Re: (WhiteOnRice)
If you noticed the problem after you took your vehicle in to get the transmission fluid changed, then most likely something happened. Few questions i'm pondering.
Where did you get your vehicle serviced at?
Did they use anything else other than Honda MTF?
Is 1st gear always an issue now with vibrations?
If you could try and detail the situation more, that would be helpful.
-Johnny
Old Oct 27, 2008 | 06:04 AM
Yeah, it's likely they used the wrong fluid (Honda MTF fluid isn't sold by any auto part dealer and Honda also doesn't give out any "equivalents" for the part dealers to use). I'd get on the mechanic's case.
DC5mike
Nov 29, 2008 01:29 PM
The Internet Tough Guy
Nov 1, 2003 12:37 PM
wessieball
Jul 20, 2002 05:29 PM
tweekerz
May 9, 2002 11:22 AM
hb_racer
Mar 2, 2002 06:20 PM
