my battery relocation method
Old Oct 23, 2008 | 07:51 AM
e30FTMFW's Avatar
Default my battery relocation method
ok ive read a few of these topics...so heres what i did...i went to the junk yard....found an e36 325i bmw ...got the whole battery setup for $10 and put it in my car ...works great, i used the terminal and it is really cool looks pretty clean, i still need to finish hiding some wiring, but heres how the terminal box looks for now
Old Oct 23, 2008 | 09:00 AM
vanrij's Avatar
Default Re: my battery relocation method (e30FTMFW)
Looks clean. Where did you relocate the battery to?
Old Oct 23, 2008 | 09:28 AM
e30FTMFW's Avatar
Default Re: my battery relocation method (vanrij)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vanrij &raquo;</TD></TR><TR><TD CLASS="quote">Looks clean. Where did you relocate the battery to?</TD></TR></TABLE>
thanks man, the passenger side in the hatch
Old Oct 23, 2008 | 07:04 PM
therotaryrocket's Avatar
why did you relocate it? and did you use all the bmw cables? what did you use to route back to the hatch? where did you route it? under the floor or under the carpet? Is your battery vented to outside the cabin?
Old Oct 23, 2008 | 07:27 PM
4DRmafia's Avatar
I really like that terminal, can you take a pic of it with the plastic cover open?
Old Oct 23, 2008 | 07:29 PM
sleepingciv's Avatar
Default Re: (4DRmafia)
more pic where is the battery?i know inside
Old Oct 24, 2008 | 07:09 AM
e30FTMFW's Avatar
Default Re: (sleepingciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">more pic where is the battery?i know inside</TD></TR></TABLE>
sure man...the top is so random like large terminal....the 1st down is the battery the 2nd is like a smaller wire that runs with the battery cable for constant...you can see it plugged in at the bottom right...and the other one at the bottom left goes to the fuse box
Old Oct 24, 2008 | 07:12 AM
e30FTMFW's Avatar
heres the pic...i just used an old box i had....i didnt know if i should use a sealed box or not....or the reasons to do so???
Old Oct 24, 2008 | 07:15 AM
e30FTMFW's Avatar
Default Re: (therotaryrocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therotaryrocket &raquo;</TD></TR><TR><TD CLASS="quote">why did you relocate it? and did you use all the bmw cables? what did you use to route back to the hatch? where did you route it? under the floor or under the carpet? Is your battery vented to outside the cabin? </TD></TR></TABLE>
it was re routed to the back already...but very poorly...he used like 16 gauge cable hahah! ...and i used all the bmw cable ...only the one cable, and its under the carpet, i didnt vent it as i wasnt sure the reason to vent it
Old Oct 24, 2008 | 06:03 PM
89civicdx's Avatar
Default Re: (e30FTMFW)
You have to put a fuse on the + near the battery I heard of the BMW stuff but never seen it.
Old Oct 24, 2008 | 06:13 PM
hatcht9x's Avatar
Default Re: (89civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRmafia &raquo;</TD></TR><TR><TD CLASS="quote">I really like that terminal</TD></TR></TABLE>
X2! that would make it really easy to add more wires for: subs/amps, more lighting etc.
nice job
Old Oct 24, 2008 | 07:10 PM
An overstrained battery can produce the explosive gas hydrogen and can also emit toxic fumes of sulfur dioxide? or something that smells like rotten eggs to the extreme. That usually only happens under severe stress conditions, like when the battery is dead or close to it, or being strained a lot.
Anyways, I used to work at Autozone, and any car that had the battery within the cabin used a battery with a vent tube that is otherwise sealed. I think the part number was 40-DL or 49-DL something along those lines. So a vented battery would definitely be an important consideration to me for safety's sake.
Cool mod though, did you have to cut the BMW cable short?
Old Oct 24, 2008 | 07:20 PM
hatcht9x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therotaryrocket &raquo;</TD></TR><TR><TD CLASS="quote">An overstrained battery can produce the explosive gas hydrogen and can also emit toxic fumes of sulfur dioxide? or something that smells like rotten eggs to the extreme. That usually only happens under severe stress conditions, like when the battery is dead or close to it, or being strained a lot.
Cool mod though, did you have to cut the BMW cable short?</TD></TR></TABLE>
I never knew a battery would do that.. but we learned about that reaction in my chemistry lab today!.. The vent is a very good idea and makes sense.. I never knew about that set-up
good info!
Old Oct 24, 2008 | 07:37 PM
e30FTMFW's Avatar
ill deff go and check out the battery box at autozone then... but strangely enough the bmw cable was the perfect length ...its strange because the car was a lot longer ..and a 4 door
Old Oct 25, 2008 | 02:00 AM
What I was talking about at Autozone was not a battery box (they might have one?), but I was speaking of a battery that includes a vent tube and is otherwise sealed part number 49-DL?.
Old Oct 25, 2008 | 05:18 AM
Or just buy a sealed battery
I think im gonna do this i like the idea
POLISHH22
Aug 22, 2015 07:38 AM
motegicivic
13
Mar 6, 2012 04:19 PM
sanjiyan69
Honda Motorcycles
11
Jun 21, 2007 05:39 PM
Boxcar
Audio / Security / Video
16
May 1, 2005 12:54 AM
G2turbo_terror
Apr 15, 2003 08:25 PM
